Old 01-18-2008, 02:57 PM   #1
Calculating Loose Fill Insulation
I am wanting to add some blown insulation to the knee wall space in my attic. I currently have 6 inches of loose fill on half and rock wool on the other half. I am wondering what R-value I need. I have read some things that say R49 in this space. If so, I would need to add R-37 or 11 inches of insulation? Is that correct or is adding too much going to cause problems?
FYI--I live in Iowa....current windchill -10.
cibula11 is offline   Reply With Quote
Old 01-18-2008, 05:08 PM   #2
http://www.greenfiber.com/homeowners/how_to_one.asp This is a link to help you calculate which accounts for settling. Adding too much wont be a problem at all. Be sure that the actual kneewall itself has insulation behind it at least R19 and covered with taped housewrap or R13 fiberglass with sealed foamboard nailed to the studs and caulked/foamed to prevent air inflltration and windwash on the fiberglass on the wall.
jaw22 is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 03:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
Insulation material reusable? KUIPORNG General Discussion 4 06-19-2006 03:38 PM
