Cable Rail - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-19-2008, 09:04 PM   #1
Cool
Cable Rail
I'm replacing my deck and am thinking of putting in cable rail. Is there any other companies that sells the "kit" besides cable rail? Does anyone have any advice on doing this? Or has anyone else just bought a swager and the cable from a local store and gone out on their own?
Our intent is to go for a contemporary look for the deck.
akairborne is offline   Reply With Quote
Old 06-19-2008, 10:48 PM   #2
Registered User
Termite's Avatar
I've seen it done, but I honestly don't recall how the ends were held in place once tightened. I do know that they used stainless steel cable so it wouldn't corrode.
Old 06-20-2008, 02:43 AM   #3
Cables and railing
Saw your post, I provide aluminum for railing kits, I would refer you to a company called Rigging Products, that's where I get my cable from. There are several types of ends that can be used. Most people use the threaded stud ends and hide with button caps and washers. There are hidden toggles that can be used with turnbuckles that hide the ends, to do this you need to use hollow tube (like the posts I sell at DIYRailing.com). This is the neatest cleanest look you can get.
Here's a picture of a project I'm working on right now.
RailingGuy is offline   Reply With Quote
Old 06-20-2008, 01:06 PM   #4
I used Suncor Stainless in Plymouth, MA for turnbuckles and wire. Jersey Strand & Cable was cheaper for the wire.
PerpetuallyRepairing is offline   Reply With Quote
Old 06-21-2008, 12:32 PM   #5
Great replies. I am looking at doing 11 cables 3"oc with 4x4's every 4 ft. I was planning on swaging one end and having a tensioner on the far end. Or I'll have the threaded studs on both ends.
Old 06-26-2008, 03:40 AM   #6
You can use a a field crimper, but your loads are limited to 700-900 lbs before they pull out, also use a 7x7 as it will crimp better than 1x19. You can purchase the cables machine swedged to get loads that are more than double. So, if you have kids that may try to climb, or jump on, machine swedged is the way to go. if not it's much easier to get the lengths right by buying a spool and cutting it in the field.
Old 06-26-2008, 09:45 PM   #7
I only used turnbuckles on one end. On the other end I used the guy wire clamps they sell at radio shack. I grabbed the wire with vise grip pliers and pulled on the vise grips with a 2 foot crowbar. I then attached the guy wire clamp & then tightened the turnbuckles. The clamps are ugly so I covered them with a board. The wires are up to 40' long and still are tight 3 years later.
Tags
cable rail , contemporary , deck , railing
In-Floor Heating Cable Trouble... sootybuttercup Electrical 24 12-18-2014 08:01 PM
Projector Receiver cable TV box bigboyjoel Home Theater 4 12-19-2007 02:23 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
Safety rail for loft Pam Remodeling 5 02-26-2007 01:55 PM
