Cabinet Walls & Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-15-2013, 09:05 AM   #1
Rewards Points: 236
cabinet walls & floor
i am asking for ideas/ways to flat, square, plumb, the walls & floor that my cabinets will be on. the walls will be out 1" from what they are now, to make room for more insulation.
i am thinking, sistering 2x4's. and doing it with those.
i want to make it easier to do a good job installing the new cabinets.
thanx
Fix'n it is offline   Reply With Quote
Old 06-15-2013, 09:28 AM   #2
Rewards Points: 13,446
Just how bad are they out?
For the walls a simple brick string pulled tight makes for an easy check to see if there all close to being flat.
Depending on the big over all picture on how far and in what directions the floors are out would decide the best way to fix it.
Old 06-15-2013, 11:33 PM   #3
Rewards Points: 81
You will have no problem installing your new cabinets unless there are major problems with your walls and floors. That is why they send oversize end panels and toe kicks with the cabinets.
one cut is offline   Reply With Quote
Old 06-16-2013, 08:21 AM   #4
Rewards Points: 236
just a quick check. it looks like 1 wall is up to 1" out at the top. all studs differ.
thanx for the string tip.
i have yet to check the floor.
Old 06-16-2013, 08:31 AM   #5
Rewards Points: 512
if the walls are opened up add blocking so you dont have to look for studs.
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
oh'mike (06-16-2013)
Old 06-16-2013, 08:43 AM   #6
Rewards Points: 236
sounds like a good idea. can you give some examples ?
Old 06-16-2013, 10:37 AM   #7
Maryland
See photo.
Pittsville is offline   Reply With Quote
The Following 2 Users Say Thank You to Pittsville For This Useful Post:
BigJim (06-16-2013), one cut (06-17-2013)
Old 06-16-2013, 12:43 PM   #8
Rewards Points: 512
perfect example pitts!
Old 06-16-2013, 07:43 PM   #9
Rewards Points: 236
i googled after, and saw that.
do you think a single 1 piece 1x8 nailed to the stud would be enough ? a 2(1 1/2)x8 would be too thick.
Old 06-16-2013, 08:19 PM   #10
DIY staff
Rewards Points: 7,174
Place the blocking so that the screws for the upper cabinets (top and bottom) will hit the blocking--the exact location will depend on the height of your cabinets,
Don't forget wiring for under cabinet lighting,if you will be installing it.
Old 06-16-2013, 08:31 PM   #11
Maryland
Just curious, but why would a 2x8 be too thick?
Old 06-16-2013, 08:58 PM   #12
Rewards Points: 236
see pic. i am using 3 1/2" roxul, and 1" xps, in my walls. so i fured out 1" to fit it all. if i put a 2x8, the 1 1/2" thickness would be to much. if i use a 1x8(3/4") i could use a spacer behind it to get the 1".
Old 06-17-2013, 09:00 PM   #13
Rewards Points: 236
so, no more help for Fix ?
the wall is about 1" out at the top.
the floor, idk yet. i don't have a long straight board to use. but, lets say it is less than 1/2", and is somewhat wavy.
Old 06-18-2013, 12:06 AM   #14
Maryland
If I understand correctly, the studs are not plumb and some are out of plane..? Can you rip some 2x stock at an angle and fasten these pieces to your studs to make them plumb and coplanar? Pulling a string line tight across the studs will help in identifying what adjustments need to be made and where.
Old 06-18-2013, 04:45 AM   #15
Ole Wood Worker
BigJim's Avatar
Rewards Points: 284
I have seen times the wall was really out and the cabinets didn't go to the ceiling or where I could hold the cabinets down from the ceiling at least one inch, I would use the french cleat method of hanging the cabinets. You can get the cleat straight and out as far as you need to. If going wall to wall you could connect the cabinets together on the floor and with some help lift them into place as one piece.
On the floor, at times, I built the base or kick separate from the boxes, place the kick in place, shim as needed to get straight and level. I made sure there was blocking behind the top of the base cabinets to fasten the base cabinets to when I could.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (06-18-2013)
Updating Timber & Balloon Framed Home (LONG POST) Pittsville Building & Construction 13 05-29-2013 12:15 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 01:08 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
