Buying New Windows On An Old House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-27-2008, 03:33 PM   #1
Buying New Windows on an old House
Hi All,
I live in an old house built sometime in the 1930's. We want to replace our windows but noticed something interesting.
There are no steel lentls across the top of each window providing support for the brick. Instead, the brickwork is layed out in a way that they arch over the window top and the bricks themselves are oriented side by side over the arch with the longer side being vertical.
My intention was to buy basic replacement windows a la Home Depot or similar.
Does this "arch" act as the support for the bricks above for the window? Can I use standard replacement windows found anywhere?
Or do I have to buy some kind of special window that has structural support capability?
I have put in replacement windows in a newer house, but there was proper steel support above it, making it more or less a swap out.
Also, when I look at the basement windows specifically, it looks like they were mortered in place. It looks like I'll have to chisel around them or break them just to get them out. Is this normal?
Any help/advice would be appreciated.....
Thanks!
water_cutter101 is offline   Reply With Quote
Old 02-27-2008, 04:10 PM   #2
PRO Siding Windows Roofs
Its near impossible to chisel them out. Instead, remove the sash, and install your new window from the inside and caulk it to the steel flange.
PKHI is offline   Reply With Quote
Flashing for New Construction Replacement Windows in Stucco House BigJimmy Building & Construction 10 11-03-2007 12:48 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
Buying house... Need advice! sweetsue777 General DIY Discussions 9 01-02-2007 04:11 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
Need advice...rotten floor joists on house I'm buying strngelitlgrrl General DIY Discussions 5 08-01-2005 09:14 PM
