Bump Out For Fridge ? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-02-2013, 11:07 PM   #16
Rewards Points: 140
for this to work, for my fridge. i would have to use no insulation. not even 1/2". and that still wouldn't be enough, better, but not enough.
i will have to chew on this.
Fix'n it is offline   Reply With Quote
Old 09-02-2013, 11:40 PM   #17
Rewards Points: 6,089
Come on, the compressed fiberglass would be insulation. Between
my direction and pictoral you should be able to figure out
a solution to " the fridge that ate Chicago "
Two Knots is offline   Reply With Quote
Old 09-03-2013, 10:19 AM   #18
Just so you know Fix'n it, I measured my fridge and it's
32 3/4" deep ( not counting the handles of course)
how deep is yours?
Between the space you pick up in the back, and bringing the
side wall out a couple of inches, it creates the allusion of a counter
depth fridge.
Old 09-03-2013, 09:58 PM   #19
Rewards Points: 140
i saw a house with a bump out. it didn't look bad.
35", no handles
anyway. i am thinking ahead, with this thread. so i highly doubt i will do anything with it this year.
Old 09-04-2013, 08:52 AM   #20
Bill Kearney
Rewards Points: 1,174
It would be pretty ridiculous to do an exterior bump out just for the fridge. The hassles of making all the transitions on the outside wall (framing, roofing, siding, insulation, etc) aren't trivial. If you're going to go through all that work then you might as well do a larger bump out for the whole section of wall. It'd cost more but it'd certainly have a better rate of return come time to sell. Whereas a strange bump out might actually decrease the property's value.
wkearney99 is offline   Reply With Quote
Old 07-24-2014, 09:42 PM   #21
Rewards Points: 140
ok guys. i am back to this. being less ignorant on this then when i started this thread. i am still unsure what to do.
my main concern is condensation on the sheathing = i don't want any rot.
plan A : cut a hole in the wall where the fridge is. frame it out as if a door. then put 3/4" plywood to cover the hole. = no wall bump out. then 1" xps on the outside ( the whole outside wall is getting 1" xps anyway). paint plywood on the inside.
so, as far as condensation on this plywood, is this a bad idea ?
feel free to modify this plan . keeping in mind as much fridge recess as possible.
thanx
Old 07-24-2014, 09:46 PM   #22
Rewards Points: 140
oh. fridge in its new location.
ok, have to wait for pic = dead batteries
gas fireplace bump out Construction? JDONE Building & Construction 2 09-03-2012 11:59 AM
Bump out? Or better ideas for a better floor plan? LTParis Remodeling 2 05-03-2012 10:22 AM
Do I need a footing for 3' X 10" bump out in the southwest.? jgonza62 Building & Construction 5 10-09-2010 12:27 PM
Removing concrete bump. brsett Building & Construction 4 09-13-2009 12:27 PM
How to make a speed bump? Grizzlyscotsman Building & Construction 5 05-14-2009 11:48 AM
