Bullet Proof Ceiling For Bathroom - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-18-2010, 09:57 AM   #1
bullet proof ceiling for bathroom
We are refinishing a bathroom (~5x8.5') with a ceiling at ~7'10" and would like to have a nice but rugged ceiling. A new high volume fan should get most of the moisture out, but am wondering if the forum has ideas about the different finishes that can be used on a ceiling. We are about to sheetrock, then plaster but would like to hear other ideas for this cabin.
Steve Burke is offline   Reply With Quote
Old 02-18-2010, 12:42 PM   #2
Why not
1x4 T&G PINE - STAINED
Especially for a cabin
Or you could go with cedar!
Add photos when your done!
noahweb is offline   Reply With Quote
Old 02-18-2010, 01:01 PM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
1/4 inch diamond plate steel always adds a nice bullet proof touch. With a nice aluminum rust resistant finish, moisture should not be an issue for a long, long time.
Old 02-18-2010, 02:28 PM   #4
Rewards Points: 5,336
What caliber are we talking about? Are we worried about incoming or out going?
Ron
Old 02-18-2010, 04:40 PM   #5
jlhaslip's Avatar
Rewards Points: 2,140
apply the drywall board and a tape coat.
Prime it and then cedar t&g as a finish surface. Smells great after a shower.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-19-2010, 10:10 AM   #6
Thanks for the ideas--diamond plate looks to be the clear winner though the wife would like something a bit more aesthetically pleasing!
The way the ceiling works now is that it is the rough side of the 2X6 subfloor for the floor above (which has a foam barrier and a floating laminate on top). To make the floor stronger and stiffer, we have screwed 1 1/8 to each of the 2x6 and a perimeter of 1.5" angle screwed to the 4X10 floor joists (@ 4' centers). The intent is to eliminate any water/steam from the bathroom to the upper floor, and make a pleasing appearance from the shower.
Old 02-19-2010, 08:52 PM   #7
Hey Steve
The issue with moisture in most bathrooms is that people shut off their fans right after they get out of the shower. Best way to remedy that is to put a timer on the fan so that it will run after you get out. Also when you buy a fan IMO I always go the next size up so that its oversized and full out more air.
Make sure you use a good primer and paint!
wnabcptrNH is offline   Reply With Quote
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 03:29 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
