Built In Shower Niche - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 09:23 PM   #1
Rewards Points: 676
I am ready to put up the Duroc in the shower. I plan on installing a simple shower niche (soap/shampoo holder) opposite side of the shower head/spigot. What do I do? Do I frame in what is to be the niche? Does it matter what size it is? Do I cut and screw in the Durock all around?
B
Beepster is offline   Reply With Quote
Old 02-24-2013, 11:04 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 770
B
I just got through with an insert, you can make it any size you want to. Yes you have to install durock back, sides, top and bottom, then seal with redgard or something equivalent. The bottom of the inset needs to be slanting downward so water will run out instead of standing. You will want to install the tape on all the seams also.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (02-25-2013)
Old 02-25-2013, 06:18 AM   #3
Rewards Points: 150
Just keep in mind when framing your opening is going to shrink thickness of tile thin set and cement board on all sides
kaschmid3 is offline   Reply With Quote
Old 02-25-2013, 08:25 AM   #4
Rewards Points: 676
OK, that is more or less what I was thinking. Didn't know if there were any tricks to it or not.
B
Redguard shower pan kjr928 Plumbing 9 02-28-2012 06:18 AM
Shower Rough In - Miscellaneous Questions tev9999 Plumbing 1 02-13-2012 09:40 PM
Shower pan/ tile problem Pawl Tiling, ceramics, marble 8 01-16-2012 09:32 AM
Tiled Shower Niche Soap Area Ideas theselenaverse Tiling, ceramics, marble 2 07-18-2011 09:17 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
