Built A Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 11:10 PM   #1
Built A Deck
I am sorry I no pictures, But what I am trying to do is, I have a sitting area I think its called a Perolow? SP, But what I am trying to locate is shade cloth to help reduce the direct sunlight, I can not seeem to find any...
Ok I happen to locate some...
splinter2 is offline   Reply With Quote
Old 04-17-2013, 05:55 AM   #2
DIY staff
Rewards Points: 7,174
Greenhouse supply company's carry that product.
Old 04-18-2013, 08:00 PM   #3
Rewards Points: 402
I purchased one from this site, and was very pleased with it. Not very expensive, and they custom make it to your specs.
https://www.thenaturalhome.com/shadecloth.htm
taylorjm is offline   Reply With Quote
Old 04-18-2013, 08:25 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
its pergola
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
oh'mike (04-18-2013)
Old 04-19-2013, 06:53 AM   #5
Rewards Points: 3,130
My last house had a pergola. To block the sun, my wife bought burlap fabric from a fabric store and sewed simple curtains. We'd hang them up in the Spring and take them down in the Fall.
Old 04-19-2013, 11:50 AM   #6
Fabric
Splinter ,
Home depot has green and tan shade screen in 3 foot wide rolls .
Az.
Az Framer is offline   Reply With Quote
Old 04-19-2013, 05:52 PM   #7
www.inspectorzo.com
Send a message via Skype™ to InspectorZo
Talking
Hey Splinter,
When you go to attach the shade cloth on the roof of the pergula, buy some furring strips (1x2 lumber) from any home improvement center or lumber yard. Every place the shade cloth passes over a wood member of the pergula, install a furring strip flat over the fabric. Use 2" minimum length nails or 1 1/2" minimum length wood screws to sandwich the fabric between the furring strip and the pergula structure.
If you need additional help, let me know. Good luck!
InspectorZo
Last edited by Gary in WA; 04-19-2013 at 11:32 PM. Reason: removed web link belongs below signature line.
InspectorZo is offline   Reply With Quote
The Following User Says Thank You to InspectorZo For This Useful Post:
Az Framer (04-22-2013)
Surface Mounted Deck Post Problem sore thumb Building & Construction 17 04-06-2013 05:45 PM
Is it safe to build a roof over my Hawai'i deck? ModelM2HB Building & Construction 11 07-03-2012 06:22 PM
Deciding on replacing deck or enclosing maj0819 Building & Construction 4 03-23-2011 02:43 PM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 10:15 AM
