-   -   Building a workshop. (http://www.diychatroom.com/f19/building-workshop-7660/)
billinak 04-09-2007 12:28 PM
I'm in the early planning stage of building a backyard workshop/sauna. I live in Anchorage, the area is fairly well drained, but this winter the frost penetrated to 8+ feet. A slab is out of the question, so I thought of using sonotubes to build the structure on, but I think pier blocks would be easier to use and manipulate. What do you think? Pier blocks vs sonotubes?
warnerww 04-09-2007 03:09 PM
8 feet WOW. How far down do they require footings for new construction up there let me say it again 8 feet WOW. I am in Eastern Wa and our frost line is 2 feet so that is how for we need to go down.
billinak 04-09-2007 03:16 PM
We had frost-jacked fire hydrants and broken lines all over town this year. I think they said on the news that frost went down to 10 feet in some areas because November was very cold with no snow to insulate.
warnerww 04-09-2007 03:25 PM
If you want it done the best way possible I would do a pole barn style and get tubes down as far as you can. Saying that I am building a 12 by 12 playhouse for my daughter and I only went down 6 inches. But for where you are at I would go down deep if you can. The ground moves a lot up there does it not? I think I heard that somewhere.
gary 04-09-2007 05:34 PM
If this workshop/ sauna is a stand a lone building, do and an Alaskian pour, slab will raise and fall when frost heave, You either have to below frost line or on top of it.
Gary
warnerww 04-09-2007 05:40 PM
Just curios what is an Alaskan pour slab. It does not get that cold in most places? Does the thing just float on top of the perma frost?
billinak 04-10-2007 12:36 PM
The municipality of Anchorage recommends a slab, sonotubes set to 5 feet, or building on skids...like on railroad ties. I'm looking at a 14' x 20' building, so slab is out of my price range. I could get the sonotubes down to 5 feet, but I'm thinking the easiest solution is to build it on raised railroad ties. Has anyone ever done this?
