Building A Wood Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-17-2011, 08:53 AM   #1
Building a wood beam
What would you say? 3 - 2 X 6 (nailed and glued with 1/2" plywood) to support existing truss rafters with a tin roof (16 on center) in FL. The span of the building is 36'. (I story building; no attic)
How often do I need to put a support?
josephs_house is offline   Reply With Quote
Old 03-17-2011, 08:55 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Need a pic or layout sketch
Not enough info for a reliable answer.
tcleve4911 is offline   Reply With Quote
Old 03-17-2011, 09:39 AM   #3
I have a sketch but being new to this I haven't a clue. I know how to send attachments and I see here that it is possible but don't seem to be able to do it. Sorry. Thanks anyway
Old 03-17-2011, 09:42 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Scan it
then post like a picture.
Old 03-17-2011, 10:56 AM   #5
I ask the impossible!
Rewards Points: 712
While you're makig a post, if you're using quick reply then click the "go advanced" button
So from there, click manage attachments, then from the new window click "browse" and find the file, select it and click ok. Then click the upload button. After it's done uploading you can click to close that window, then finish your post and the picture will show up under your post when you finish the post.
So with that said, this is more likely than not to be a question that ought to be directed to an engineer. It sounds like you're asking about something for an existing structure, and assuming it was built to code, some more info about why you think a beam needs to be added and what you intend to accomplish with it?
Being that this is in Florida, I'd guess that there may be hurricane related code requirements that I would not be familiar with...
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 03-18-2011, 01:29 PM   #6
If your 2x6 is #2 douglas fir, then with a 5' span it can support 908 lbs. 6' span = 756#; 7' = 648 lbs; 8' = 567#; 9' = 504; 10' = 453. If you add three pieces together, then they can carry 3x.
Now, look up the weight of 2x4 by the foot and add up how much is in half your truss. Add in your purloins, add in the weight of your roof, and anything else that will be supported. Look up the wind loads for your location and add them in. Be sure you use the appropriate fasteners.
pyper is offline   Reply With Quote
Wood beam dryrot and iron beam rust Waivy Building & Construction 6 03-04-2011 08:45 AM
Old Building problems jake62 Building & Construction 5 08-20-2010 08:32 AM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Finding a suitable flooring material for Wood frame Condo building lsgko Flooring 1 02-20-2009 02:38 AM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 12:48 PM
