Building A Wall Under A Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 01:51 PM   #1
Building a wall under a beam
Hey guys, I am trying to figure out the best way to build a wall in my basement under a metal I-beam that is 4.5 inches wide. The person who owned the house before me actually framed a wall there already which is pretty close to what I wan't but he used 2x4's and the beam is a whole inch wider then the wall studs so I am not sure how you could put up the drywall and such with the wall built in that way. Thanks for your patience I am a total newb to this stuff.
wfrench is offline   Reply With Quote
Old 12-01-2010, 02:28 PM   #2
Rewards Points: 558
Box the beam in and call it a day…
epson is offline   Reply With Quote
Old 12-01-2010, 04:12 PM   #3
ok, that works for me. Thanks
Old 12-01-2010, 04:28 PM   #4
Framing Contractor
Frame the 2x4 wall flush to one side of the I-beam and then pack out the other side of the wall with 5/4 which measures 1".
Joe Carola
Joe Carola is offline   Reply With Quote
Old 12-01-2010, 05:56 PM   #5
I'm sorry Joe, can you explain this "pack out the other side of the wall with 5/4 which measures 1". Is it using multiple layers of drywall that you mean or something else? Sorry like I said I am a total newb.
Old 12-01-2010, 05:59 PM   #6
Electrician
What he is saying to do is put a piece of 5/4" (1" strips of wood) down each stud to shim the drywall out far enough to match the top.
I say screw it, just do like this guy is trying to do on one side: How do you do this straight edge?
VersaBar is offline   Reply With Quote
Old 12-01-2010, 06:18 PM   #7
Either way is good. Just box the beam in, or build out one side 1". If you build the wall out, I'd put the 5/4x3 (rip a 5/4x6 or use 5/4x4) horizontally. It'll be easier to drywall
mrgins is offline   Reply With Quote
Old 12-01-2010, 08:07 PM   #8
Great, I got it. Thanks for explaining that to me.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Zone 6 - Wall Insulation: building out 2x4 walls DoItMyselfToo Building & Construction 15 05-06-2011 08:36 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 05:28 AM
Replacing existing wall with support beam or I beam sourdough Building & Construction 4 08-06-2008 09:42 AM
