-   -   Building a temporary workshop inside of large pole building (http://www.diychatroom.com/f19/building-temporary-workshop-inside-large-pole-building-64742/)
HandyDave 02-17-2010 08:39 PM
I am exploring the possibility of building a temporary workshop inside of a pole shed to restore a couple of tractors throughout this year. The size would be 20x 24x 8. The pole shed currently has compacted "Screenings" ( small gravel and gravel binder when compacted is just as hard as concrete) for a floor which is level and dry
So for flooring I am thinking of laying down a vapor barrier, laying treated 2x4's 16"oc and covering with 3/4 inch tounge and groove sturdi floor. I will then continue building up from there as if I was building on a floating slab.
My question is do you think the sturdi floor will support the weight of the tractor? 2500 lbs Remember the studs will be laying flat (the wide side up) directly on the ground
Ideas - Suggestions?
