Building Steps For A Work Shop - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-08-2010, 02:54 PM   #1
Question
Building steps for a work shop
I'm building a work shop from plans that is 16' X 24'. I have the four walls framed, and am ready to install the ridge board, rafters and joists. The question is, do I install the exterior OSB siding first, and then the roof, or the roof first? If I install the 1/2" OSB siding first, my thinking is that the birds mouth of the rafters, will have 1/2 " less solid surface to rest on top of the double top plate. I can't find any clear answer on this. Thxs, Michael
jbros3 is offline   Reply With Quote
Old 08-08-2010, 03:08 PM   #2
Framing Contractor
Doesn't matter either way. If you don't install the sheathing first you make the seatcut on the birdsmouth 3-1/2". If you install the sheathing first you make the seatcut 4". You can also keep the seatcut 3-1/2" even with the sheathing on first. There is plenty of bearing for the seatcut. Don't worry about it at all about the 1/2".
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-08-2010, 04:48 PM   #3
Work shop question
Thanks much for your reply, and explanation.
Tags
roof first then siding?
Building a woodwork shop in backyard deck99 Building & Construction 9 02-05-2009 10:37 AM
Electrical work in Branford, CT - Can I do it? ControlTech Electrical 11 01-11-2009 12:45 PM
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 12:19 PM
Use Tyvek home wrap on new shop? MaxRules Building & Construction 4 07-22-2008 07:41 AM
