Building Stairs LVLs Or Dim Lumber - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-16-2008, 09:10 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,314
Building Stairs LVLs or Dim Lumber
I'm buying material for stringers today. The choice is to build them out of 3 - LVL stringers or 4 standard 2x12 dimensional lumber. It's a relatively short run of about 12 steps. There's a big price difference between these two materials plus it's an expensive mistake if I mis-cut one of the stringers out of LVL. What do you usually cut stringers from?
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 02-16-2008, 09:20 AM   #2
ICF Construction
I prefer the LVL's, you will get three consistant pieces of wood, 2x12's good chance you could get 4 different pieces of wood, warped, twisted, checking. Mind you, if you are able to hand pick the lumber use the 2x12's and save a buck or three
Chris
Chris Johnson is offline   Reply With Quote
Old 02-16-2008, 07:10 PM   #3
I just built my basements steps out of 2 X 12 LVL's and it can hold an elephant! I only used two stringers and the stairs are 34" wide. They say you should use solid wood without knots but I was not able to find any. It was a lot of fun but take your time planning it out.
teachtech is offline   Reply With Quote
Old 02-17-2008, 09:30 AM   #4
I have gas!
Alright, LVLs it is. My credit cards are getting a bit stretched, but I guess it's worth it. Thanks.
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 08:16 PM
Prefab or custom stairs? brokie General DIY Discussions 1 01-21-2008 08:11 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
Building stairs layout helpless handyman Carpentry 12 08-17-2006 01:21 AM
