-   -   Building Stairs LVLs or Dim Lumber (http://www.diychatroom.com/f19/building-stairs-lvls-dim-lumber-17172/)
Clutchcargo 02-16-2008 09:10 AM
63 Attachment(s)
I'm buying material for stringers today. The choice is to build them out of 3 - LVL stringers or 4 standard 2x12 dimensional lumber. It's a relatively short run of about 12 steps. There's a big price difference between these two materials plus it's an expensive mistake if I mis-cut one of the stringers out of LVL. What do you usually cut stringers from?
TIA
Chris Johnson 02-16-2008 09:20 AM
I prefer the LVL's, you will get three consistant pieces of wood, 2x12's good chance you could get 4 different pieces of wood, warped, twisted, checking. Mind you, if you are able to hand pick the lumber use the 2x12's and save a buck or three
teachtech 02-16-2008 07:10 PM
I just built my basements steps out of 2 X 12 LVL's and it can hold an elephant! I only used two stringers and the stairs are 34" wide. They say you should use solid wood without knots but I was not able to find any. It was a lot of fun but take your time planning it out.
Clutchcargo 02-17-2008 09:30 AM
63 Attachment(s)
Alright, LVLs it is. My credit cards are getting a bit stretched, but I guess it's worth it. Thanks.
