Building Stair Treads From 5/4 X 4" Oak T & G - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-26-2011, 12:23 AM   #1
Building stair treads from 5/4 x 4" Oak T & G
I have a set of stairs that was carpeted but want to install Oak 5/4 x 4" flooring as treads and 1/4" oak plywood for risers and finish boards for the walls. My question is: I want to use 3 of the T & G Oak boards to make the steps. I plan to blind nail the rear 2 boards using glue also and angle drill from underneath the front board along with glue. Will this last as it will be a considerable amount of work and what type of glue would you recommend?
BlastX is offline   Reply With Quote
Old 01-26-2011, 08:24 AM   #2
Is this going over the existing treads?? If yes, not a good idea. It throws off the top and bottom step spacing and could be a tripping/falling hazard. And removing treads from an existing staircase is usually not a simple job.
Old 02-01-2011, 08:50 PM   #3
Continuing
It will be over plywood construction. the top floor has 5/4 oak and the stairs should be at 7" when finished
installing oak stair treads advice bfan781 Carpentry 20 01-02-2011 11:56 AM
Refacing stair treads Stair newbee Flooring 2 08-10-2010 11:35 PM
New stair treads and flooring rickkeeter Flooring 2 02-24-2010 11:16 PM
Ugly old painted stair treads, with seriously raised grain. Salvageable? CharmCityFixer Flooring 9 01-29-2010 07:40 PM
Scribe Cutting Oak Stair Treads kcdave Carpentry 2 03-18-2008 08:13 PM
