Old 04-04-2008, 11:43 AM   #1
Building stadium seating for home theater
We are starting the platform for the home theater. Do we have to use pressure treated lumber? We are acid staining the concrete floors, so they will remain concrete. The wood will be in direct contact with the concrete. I thought we might be able to get away with regular lumber for this.
QueenL is offline   Reply With Quote
Old 04-04-2008, 01:37 PM   #2
check out www.avsforum.com the dedicated hometheater area...you will find all the Home Theater riser info you will ever want.
chpwaman is offline   Reply With Quote
Old 04-04-2008, 02:51 PM   #3
concretemasonry's Avatar
If the concrete is slab on grade, then any wood incontact with it must be P.T. The acid stain is of no consequense. You can use separating materials if they have the right properties.
concretemasonry is offline   Reply With Quote
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
