Building A Solid Railing... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-01-2012, 05:40 AM   #1
Building a solid railing...
For a raised walkway. We have built the frame with PT 2x8 well cross-membered. Looking for the most solid way to attach 4x4 uprights for the railings.
We are thinking carriage bolting them to the outside of the frame will work. They will be free-standing; meaning that the rails will attach to the 4x4 and will not go back to a solid structure such as the building.
Any ideas on the topic?
lemonbomber is offline   Reply With Quote
Old 05-01-2012, 12:14 PM   #2
Rewards Points: 13,456
Anyway to post a picture?
Trying to figure out if it's raised why did you not set the post in concrete then frame up the decking.
If you framed it with 2 X 8's where does the 4 X 4's come in. Where they runners on the ground that the frame was built on?
Old 05-01-2012, 04:24 PM   #3
2*8 frame...
raised about 6 inches off ground on concrete blocks/rounds . they are sitting on a stable yet crappy looking old asphalt walkway. the 4x4 's are for the railing kit that is to be attached. it has those slip over pvc covers for the wood.
someone had been telling me to make a one inch notch on the 4by and carriage bolt it to the 2x8 frame work.
Old 05-01-2012, 04:31 PM   #4
Rewards Points: 636
no do not do that it will fail no notching 4x4
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-01-2012, 04:38 PM   #5
Rewards Points: 636
try one of the following
http://www.strongtie.com/ftp/fliers/DIY-DECKPATIO08.pdf
http://store.ideas-for-deck-designs.com/anchors.php
and these are the best to use check out the video s on the right of page
http://www.fastenmaster.com/details/...ng-system.html
also check technical data for anchor pattern
Old 05-01-2012, 04:46 PM   #6
Rewards Points: 636
i love the fasten master screw line they are awesome headlok, ledgerlok, and thrulok are great price if you compare it to a 1/2 hot dip galvinized carriage bolt washer and not and a lot faster to install no pre drilling and no wrenching
i also love there guarddog exterior screws do not break or very very rarely strip out head
Old 05-01-2012, 04:53 PM   #7
Civil Engineer
Rewards Points: 4,698
Code has increased the required lateral resistance of railings significantly over the last 15 years, in part due to some spectacular fatalities involving people falling off balconies to their demise. There are a number of different ways to attach the 4x4's to the framing. I recommend following your local code. If you don't have a local code, you may want to follow the International Residential Code, that is what my town uses.
My town uses the 2006 code, and there is an entire section on proper attachment of the 4x4 posts to the deck, on pages 15 and 16. A couple of points worth thinking about. According to IRC, the posts cannot be notched. Code also requires use of a minimum of two 1/2 inch diameter through bolts and washers (carriage bolts are not recommended due to tensioning issues). You can vary from the recommended attachment method if approved by your local building inspector. You can get the code on line, at least the 2009 version is available, I don't have the website but search this forum, there have been several recent posts that give the link.
Daniel Holzman is online now   Reply With Quote
Old 05-01-2012, 05:08 PM   #8
Rewards Points: 636
fastenmaster thrulok has tech. sheet to submit to building code department to show it is code compliant
holzman i think you would love fasten master products
Extending height of deck railing tntworks General DIY Discussions 4 03-11-2013 07:16 AM
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
How/ What to do with the railing? Fantastic Building & Construction 2 02-22-2011 09:04 PM
Tile under or around a railing? RandyKlein Remodeling 3 06-13-2010 09:08 AM
How to fix broken step railing? robertr4836 Carpentry 2 04-18-2008 11:19 AM
