Building A Slump Block Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-19-2011, 02:31 PM   #1
building a slump block wall
wanted to know if it was nessasary to have control joints on a fence wall thats 150ft long by either 4 or 6 ft high.already put a 24x8 inch footing with rebar and every 4 ft upright rebar. asking for alittle input thanks in advance
wayne beresford is offline   Reply With Quote
Old 02-19-2011, 03:54 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There's a term I have never heard. What is it?
Built a lot of retaining walls over the years but this is a new term to me.
XXX
Old 02-19-2011, 04:17 PM   #3
concretemasonry's Avatar
Rewards Points: 2,626
Wayne -
where are you located? If you are in CA or AZ slump block privacy walls are common and most municipalities have standard construction details. - That is a good place to start.
Normally, the walls are not 150' long without an opening, pilaster or height change that serve as joints, it is not a problem. For a 150' long wall the same height, you can expect some minor vertical cracks. they are natural with any long concrete structure.
Dick
concretemasonry is offline   Reply With Quote
Old 02-19-2011, 05:06 PM   #4
thanks Dick . im in az and im following the conture of the land. i didnt want to joints im trying to make it look like adobe
Zone 6 - Wall Insulation: building out 2x4 walls DoItMyselfToo Building & Construction 15 05-06-2011 08:36 AM
2.5 to 3 ft ht standard block wall cprao Building & Construction 5 07-31-2010 11:11 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Building new wall Gabriel24 Building & Construction 1 03-28-2010 08:38 PM
building a heavy wall crmotoxr Building & Construction 2 01-31-2009 09:05 PM
