Old 01-25-2009, 01:55 PM   #1
Default building shower walls with concrete
I am considering creating the walls in a new shower with poured concrete. I have seen a building made with wall forms created by wooden boards set side by side and the concrete was poured between 2 forms. Once hardened, the boards were pulled and the boards gave an interesting texture to the concrete. I have a pretty good idea of how to do this but am wondering if anyone out there has done anything like this before. If so, what did you learn? What would you do differently? These walls will attach to the current walls which are ICF blocks. The shower walls will be about 4 inches thick. I plan to use hardware cloth as reinforcement and will have short rebar pieces sticking out of the ICF walls to attach the shower wall to the support walls. Also, I plan to use a small aggregate concrete.
Thanks for any insight you can give me!
canyongirl is offline   Reply With Quote
Old 01-25-2009, 04:02 PM   #2
Ive never seen what your trying to do before but the first thought is whats supporting these new walls from below?
II Weeks is offline   Reply With Quote
Old 01-25-2009, 05:34 PM   #3
Default concrete shower walls
I have built a concrete shower floor that sits on the concrete pad. The walls will sit on this. I plan to line this shower floor with a flexible shower pan and run it up the wall, then build the frames and pour the walls. This way it will be inbedded into the wall, as if behind a tile wall.
Old 01-25-2009, 05:39 PM   #4
take some pictures during this. i would like to see how it comes out.
Old 01-25-2009, 06:16 PM   #5
concretemasonry's Avatar
Pouring a 4" concrete wall is a work different than pourig a floor slab.
You will need a lot of bracing the keep the wood forms is place and reasonably square. Next you will need ties to hold the 2 sides of the 4" wall together and not bulge or blow out. Your form boards would have to be at least 3/4" plywood plus you will ne 2x4's, 2x6's or 2x8's vertically to attache the bracing to.
Keep in mind that concrete is over twice as heavy as water and everyong know how much pressure is created laterally or vertically. - You are fighting Mother Nature and gravity.
block would be more feasible if you can find a suitable surface to apply to the walls.
concretemasonry is online now   Reply With Quote
Old 01-25-2009, 06:18 PM   #6
If your only interest is in the look of board-formed concrete, then consider doing vertical stamped concrete. It solves most of the problems with forming and placing a real 4" thick concrete wall.
It ain't Rocket science unless you are building rockets
Tscarborough is offline   Reply With Quote
Old 01-25-2009, 07:01 PM   #7
Building codes guy, Mod
thekctermite's Avatar
Forming, reinforcing, and placing concrete aside...How do you intend to sufficiently seal the concrete shower to prevent water from permeating it, especially on the floor? Hopefully you placed an integrated sloped membrane in the shower floor to allow water that penetrates the surface to get to the drain.
thekctermite is offline   Reply With Quote
Old 01-26-2009, 11:37 AM   #8
For the floor of the shower I will place a flexible shower pan (its like a big thick sheet of rubber) and the floor slopes to the drain. I will tile on top of this. The walls I will seal with a concrete sealant. This is a bathroom that probably won't be used often and we are in the high desert where things dry quickly. There is a window right next to the shower and an outside door should we need to let more air in. After living most of my life in Florida and living with constant mildew, I am amazed at how slowly it grows here!
But I was wondering if you know if portland cement without aggregate is less pourous and may be a better choice for the walls? And do you recommend a particular sealant? I am very interested in products that don't offgas and are of low toxicity.
Thanks for corresponding!
Old 01-26-2009, 12:14 PM   #9
You will need aggregate (sand and pea rock) and reinforcement for strength and crack control. Portland and water is too weak and will crack in addition to being very expensive.
Old 01-26-2009, 12:25 PM   #10
Agreed, you definately need aggregate! There are a myriad of options other than basic gravel limestone stuff...Pulverized granite, etc.
Old 01-26-2009, 02:24 PM   #11
Marble dust used as the fines will also assit in the waterpoofing of the concrete.
Old 01-26-2009, 05:13 PM   #12
Thanks for your imput everyone! It is good to know that this is do-able and not a totally crazy idea. I will write when I complete it to let you all know how it went.
PS--I have a (chocolate) lab too!
Old 01-27-2009, 08:08 AM   #13
congrats on picking icf system - you'll absolutely LOVE it,,, if you've resolved support issues, it is ' do-able ' however ea wall measuring 3.0 x 6' will weigh 555# - 3 walls = 1,700# + steel reinforcement + floor,,, that's a very serious static load not to mention the difficulty in placing conc,,, vertical thin-stamp makes much more sense to me & we've done both for ourselves & clients,,, form bracing'll be critical so overbrace,,, we lined the forms w/poly & pulled 'em after 24hrs,,, you could use liteweight aggregate but its really not nec in this case since sufficient support's already present,,, plain conc can look good but use a VERY good conc sealer ( solvent based ).
yesitsconcrete is offline   Reply With Quote
More On This Topic
Here’s some of the things that we’re going to be using today. Some of these things won’t be used only because instead of the blocks I’m going to demonstrate the straw bales being mounted to, you’re typically going to have an... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about attaching our wall to concrete. Since our wall will be sitting on concrete, there is a couple of different ways that we can attach our wall to that concrete. The... Read More »
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
Right now we’re going to actually set the bales, we’re going to actually lift the bales up. And you want to try to not stress the wires and whatever any more than you have to. In order to set the bale on the very bottom, you’re going to... Read More »
We've mixed up some more concrete and we're just in the process of finishing off this job here. Put some back in the bucket, here. Once this dries, in a day or so, we can come in and lay our tile and that will finish up our floor. The reason that I'm... Read More »
Cutting out a concrete basement floor jeffhoward001 Building & Construction 17 05-02-2009 10:50 AM
Concrete Board in shower, need help please! floxy General Discussion 18 03-01-2008 08:15 PM
waterproof plaster shower walls carsokk Remodeling 2 01-31-2008 10:14 AM
Hi all newbie here Building a Tile Shower vonlea Building & Construction 6 05-09-2007 12:16 PM
building concrete walls miller4000 Carpentry 0 03-17-2007 03:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
