Yep - Thats a relatively easy way to do it. Of course you need the drains to line up with the pan drain, etc. Pans can really vary in pricing depending on what you get. The thin plastic ones can flex which is annoying but can be made more solid with a good base. Base could be sand, foam, mortar, or others depending on your situation and base.
Where can I buy these pans? Also will the pan allow you to frame right up against it so that when I install the wall it's flush aginst the pan? Any good recommendations are welcome. Do I frame first, then install pan?
You buy the pans at any plumbing supply store. Lowes, Home depot may also have. They come in fiberglass, plastic, cultured marble and others. There are different sizes too. Square, rectangular, triangle, corner styles, etc.
Read the instructions that come with the particular pan you select. Usually you frame right up to it. Actually you frame first, according to the direction, then install the pan between the studs.
Pay particular attention to the manufactures recommendations for weather or not to lip the tile backer over the pan, or not, to shim backer, or not, how close to bring the tile to pan, etc.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
