Old 08-01-2006, 09:06 AM   #1
building a shed on a sloped hill
what is the best way to put a shed on land with a slope
tom1st is offline   Reply With Quote
Old 08-01-2006, 09:59 AM   #2
Oldguy
Rehabber's Avatar
How steep a slope? How larrge a shed?
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 08-01-2006, 10:12 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Where is the door to be located? That really is going to be the predominate issue to look at.
If the door were to be on the side that is aligned with the slope, then that complicates things.
Otherwise, you could pour your footings to level the shed structure.
(Using your poured concrete sonic tube footings to set the shed to level)
That would mean that one end would sit above the grade. If it is a significant grade, you could cover that space under the shed with lattice work for 'looks'.
- Build Well -
Old 08-02-2006, 03:22 PM   #4
newbie home renovator
We just did this in a back corner of the yard where the yard sloped down. We dug a flat foundation into the slope and built a masonry wall. The shed will be built on the wall w/ three concrete pillars in back for support. We will use the space underneath for extra storage.
bellacosa is offline   Reply With Quote
Old 08-02-2006, 08:04 PM   #5
Yep. My thoughts exactly....
And with that:
What type foundation?
What is the frost depth?
manhattan42 is offline   Reply With Quote
Old 08-03-2006, 08:22 PM   #6
In my case, I built a 10'x12' shed on a slope in my back yard.
About 4' of the front (door side) is on level ground on pier blocks croncreted in.In the back I used 10" Kolumn Forms or sonic tubes.
At the steepest part I have about 3 1/2' of exposed form.
I used three rows, the two outer rows at 8' o/c and one row at 4' o/c between the outer rows. From front to back the forms are 4' o/c.
4"x6"x12' P.T. beams were used. The floor joists are 4"x6"x10'16" o/c
The rest is up to you. I built mine about 3 years ago, I use it for my lawn and garden tools and my Kawasaki Mule
Tyler707 is offline   Reply With Quote
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 03:11 AM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 05:24 PM
Subpanel to Shed - Check my plan NateHanson Electrical 9 04-26-2007 10:56 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
Venting a shed roof with 2/12 slope atulc Roofing 5 08-25-2006 08:28 AM
