Building Shed On A Slope - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-05-2011, 06:00 PM   #1
Building shed on a slope
I am planning to build a 12x12 shed on moderate slope. We have 42" frost line where I live so I'll be drilling some fairly deep holes :-( About 1/3 to 1/2 of the shed will sit on pretty level ground but the remaining part will be hanging up in the air where the grade steepens. I figure I'll have to build what amounts to a ground-level deck to use as the base for the shed. So, with that in mind I drew up a plan that I think might work but want some expert advice and also wondering if there is a better, easier, and/or cheaper way to accomplish the same thing. Any advice would be appreciated, thanks!
I'm trying to stay away from using 4x4 "skids" which I've seen some people do as it just adds to the height. I'd rather sandwich 2x8's together to form the outer rim joists and one center beam and rest those on the piers. I am thinking that 6 of the piers would rise all the way to base of the 'deck' while I'd have to use 4x4 PT lumber for the 3 on the steepest part of the grade. Hope that makes sense...please see picture.
Augy is offline   Reply With Quote
Old 05-05-2011, 07:03 PM   #2
Not a Noob or Boob
I wouldn't build any of it below grade. If you do, I would recommend a block wall and some weeping drains to divert water around the shed. Just my two cents
Rob1975 is offline   Reply With Quote
Wood Shed Construction- Town wants concrete pad? TJ_in_IL Building & Construction 20 07-26-2011 09:21 PM
worth it building a shed instead of buying?? Gnfanatic Building & Construction 15 07-07-2010 11:02 AM
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 06:28 AM
Building a shed under my deck. stevez Building & Construction 9 04-29-2009 09:19 PM
Building rafters for small shed simonb Roofing/Siding 4 07-15-2008 12:32 PM
