Old 03-13-2012, 06:57 AM   #1
Building a shed...am I not thinking of something?
Ive decided I want an inexpensive place to store mower, garden tools etc... I came up with the idea of a simple dirt floor shed with a pole design, 10x16. After reviewing product costs I came up with the idea to sink 5 (4 corners and one midway to frame the door) 6x6's that have been notched to receive 2x6 tongue & groove lumber running horizontally. It seems cheaper than sinking poles every 4' and using t11 plywood for siding. My sketch looks pretty nice and I cant think of a reason it wouldn't work, but I cant find anyone online that has done anything like it. So either I'm a genius, an idiot, or its just an average idea that normal people dismiss.
A 12' run of the 2x6 t&G concerns me some because of warping over time, but I figure if I nail a few 2x4's vertically on the inside of the shed it should hold them together. I would love some input from people that know what they are taking about cause I dont.
Madison is offline   Reply With Quote
Old 03-13-2012, 08:00 AM   #2
Dirt floor not a good idea, unless you live in a desert. All wood in contatct with dirt MUST be pressure treated, or it will quickly rot out. Some type of foundation is needed, even for a small shed, or ir will settle/rack over time.
Old 03-13-2012, 10:38 AM   #3
STAFF
BigJim's Avatar
I have built several pole barns but I used phone poles instead of pressure treated lumber. If you are bent on a dirt floor you might want to build it up on the inside and pack it so water can't get in and even then, like Bill said, you might want a footing and maybe a row of blocks or two or any siding close to the ground will rot pretty quick.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 03-13-2012, 11:08 AM   #4
I would use build a floor even putting it on a pier blocks with a Marine grade plywood would be better then dirt. Other wise your throwing effort after foolishness.
Nailbags is offline   Reply With Quote
Old 03-19-2012, 07:59 PM   #5
The spot I have in mind is a little rise, so a soaking puddle of a floor isnt a concern. The T&G would all be pressure treated and stained. Really just looking for a cover for my mower and a place to put some basic garden tools. The construction is what I have a concern about. Im thinking it will take less than a weekend by myself since once the posts are placed and cured the sides will take less than an hour and Ill take the rest of the weekend making some prefab trusses and putting on shingles. I priced out materials at $850 for the whole thing at 10x16, plus the cost of a sliding door and Ill buy the hardware at the the local farm and country for ~$50. Just seems like I must be missing something since thats less than the crummy kits the box stores sell. If I pull this off Ill post some pics.
Old 03-19-2012, 07:59 PM   #6
Thank you for the responses.
Tags
construction, garden shed, pole barn, shed
Building a Shed FKampf Carpentry 15 08-17-2011 09:50 AM
Foundation for a lifetime shed sifuhall Building & Construction 7 07-10-2011 08:51 PM
building a storage shed blk90s13 Landscaping & Lawn Care 17 03-22-2011 11:42 PM
Building a shed under my deck. stevez Building & Construction 9 04-29-2009 10:19 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 07:19 AM
