Old 06-14-2009, 08:53 PM   #1
building a screened in area on deck - deck heaves in winter
last winter the new deck(24w x 12d) i put on the front of my camp heaved. it was attatched to the camp and lifted it off the block foundation - not good!
my next step is to make it a 'floating' deck but i want to build a screened in room on it. the problem is i wanted to use the camp as the back wall. obviously not possible now. the only option i can come up with is to build a back wall with a sliding screen door in front of the patio doors to the camp - wife doesn't like this idea - doesn't want two screen doors together. here in lies the challenge - try to come up with a solution that works and pleases her!
burnt. is offline   Reply With Quote
Old 06-15-2009, 11:35 AM   #2
Brace the deck, excavate under each post and put in a concrete footing that extends below the frost line in your area. Do each post one at a time so your deck stays stable.
You've got all summer to do it and next winter you will be glad you did.
Building new deck and screened in Gazebo - Wood or Composite? Todd1 Building & Construction 10 11-05-2010 12:24 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General Discussion 20 05-18-2008 12:05 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Building Cabin.. Can I use cedar deck 5/4 radiusx6 on floors? Going Nuts Flooring 1 07-19-2006 07:37 PM
Building a Deck "screwed" econdave Building & Construction 8 05-02-2006 07:01 AM
