Building Room Inside A Barn - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-10-2012, 08:15 PM   #1
Building room inside a barn
I am looking into building a roughly 19x13 room inside of an old 40x25 post and beam barn. The floor in the barn is just dirt. I want the room the be drywall on the inside and insulated. Probably just put osb on the exterior. The barn stays very dry throughout the year. My question is, what could i use as a foundation for the room besides pouring a concrete slab that would be very cheap and effective for this type of construction? I am going to try and tie two of the wall into the current post of the barn for added support. Thank you for any advice you can provide.
metallic806 is offline   Reply With Quote
Old 10-10-2012, 08:25 PM   #2
Rewards Points: 13,274
Easyer, and faster to just build it as if it was shed.
It still can not be in direct contact with the floor. It needs to be build on skids or 4 X 4 post set in the ground below the frost line.
Old 10-10-2012, 08:29 PM   #3
Would you just use a gravel base and level skids off that? I was thinking if I build it in the barn then I wouldnt have to put a full fledged roof on it.
Old 10-10-2012, 08:31 PM   #4
And you would be correct. Make sure to use at least, 4 would be better skids.
A simple flat roof would be fine.
Old 10-10-2012, 08:56 PM   #5
Ok sounds good thanks. So you dont think it would necessary to tie the walls to the barn at all?
Old 10-10-2012, 09:00 PM   #6
Why would you? There was no pictures or drawings so I'm just guessing.
Old 10-11-2012, 12:45 AM   #7
AHH, SPANS!!!
Rewards Points: 1,166
How tall is the ceiling in the barn?
hand drive is offline   Reply With Quote
Old 10-11-2012, 04:48 PM   #8
Ten foot ceiling
Old 10-11-2012, 05:55 PM   #9
DIY staff
Rewards Points: 7,174
Joe is right----I built something similar inside an unheated garage to use as a laundry room----
So get it up off the dirt---you need some air circulation under it if you use wood framing for the floor---
Can portable AC unit intake air from inside room? bludshot HVAC 20 05-13-2010 05:41 AM
Painting aluminum siding but on inside of room Miguel&Dawn Painting 2 09-07-2009 08:57 PM
Cold Room mikelbeck HVAC 14 01-16-2009 09:21 PM
Building room in basement... Packer Backer Remodeling 4 09-02-2008 09:20 PM
Building a deck on an inside corner ternstes Carpentry 3 06-16-2008 09:45 PM
