Building Roof Soffits? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-26-2012, 01:12 PM   #1
Building roof soffits?
Got an older house and would like to cover the exposed eaves and rakes with soffits to help with cleanup in the future, i.e. cobwebs and keep birds from pecking holes. I was wondering what material to use and what nail size/nailer? Could someone help me a bit with a little guidence? Thanks.
jfharper is offline   Reply With Quote
Old 11-26-2012, 03:11 PM   #2
kwikfishron's Avatar
Rewards Points: 998
Your options are couple styles of wood, vinyl, aluminum or fiber cement.
Vinyl and aluminum you don’t have to paint but don’t always look right on some homes.
How there installed varies some depending what type of siding and fascia set up you have now.
Posting a couple of pictures of your house would help to be able to tell you what exactly needs to be done for your particular situation.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
mae-ling (11-26-2012)
Old 11-26-2012, 08:52 PM   #3
AHH, SPANS!!!
Rewards Points: 1,166
typical soffit material is 3/8 BC or AC plywood but there are many different materials as well even tongue and groove soffit. You can either have a leveled soffit that requires added framing or follow the rafter roof pitch and attach underneath the rafters with the soffit material.
hand drive is offline   Reply With Quote
Old 11-26-2012, 10:23 PM   #4
Registered User
Rewards Points: 526
Good time to add soffit venting usually not found on older, exposed eaves, Use continuous angled louvers, screened, right next to the fascia board for optimum air-flow. The block venting notches/holes should leave most of it intact for structural strength.
Gary
Repair + roof coating options Fishbone90 Roofing/Siding 23 11-12-2012 09:44 PM
Building a deck on a tar and gravel roof grmachine Building & Construction 2 05-30-2012 10:00 PM
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 10:50 AM
Flat repair roof of condo building Stillwerkin Roofing/Siding 7 03-02-2009 06:34 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
