Building Ramp For Hugh Shed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 09:31 PM   #1
Rewards Points: 588
Building ramp for hugh shed
I Need a ramp on my shed to get things like my push mower in and out of my shed. My shed is built on very unlevel ground which is going to be a challenge I have to overcome. One side of the double doors is about 20" off the ground while the other side is 26" off the ground. I want a solid ramp am the heaviest thing going in and out of it will probably be my push mower. My plan right now is to set a few rows of 4x4s set in concrete with the tops cut at a 20 degree angle. I will go 3 across and however many down until I get the the ground spaced maybe 2' apart. Then I am not sure from there.
nikeman is offline   Reply With Quote
Old 06-24-2012, 11:54 PM   #2
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
You could build up the drop off with road stone and compact it as you go. You can drive a car on compacted road stone and if it settles, just add more.
But with just a push mower as your heaviest tool, you could build a wooden ramp with 2x4s and 3/4" PT plywood. You wouldn't need the concrete.
JulieMor is offline   Reply With Quote
Old 07-02-2012, 09:32 PM   #3
Rewards Points: 588
Someone gave me the idea to build a platform and then have the ramp go down the side since the one side is so much close to the ground meaning the ramp would be much shorter. Plan is to bring it out about 6' and of course go all the way across both doors. Will 9 4x4 posts (3 front, 3 middle, 3 back) spaced 2' apart be enough? Then just lay the decking across and screw them down? I guess putting 2x6s crosswise flush to the top of the 4x4s would be a good idea.
Old 07-03-2012, 08:21 AM   #4
JulieMor's Avatar
Rewards Points: 518
Typical building construction calls for floor joists to be a minimum 16" on center. I realize your ramp probably won't even require a permit and the loads are fairly light, but it's a small project. I'd go with 16" centers.
Old 07-03-2012, 08:41 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,... Sounds like yer Waayyy Over thinkin' this....
A couple wheelbarrows of stone, 'n it's Done...
Bondo is online now   Reply With Quote
Old 07-03-2012, 08:54 AM   #6
Rewards Points: 588
I would need a lot more than a couple wheelbarrows and I just don't want all the gravel back there getting washed away and getting scattered all over the yard by my dog. I want something that looks decent also.
Building ramp for shed nikeman Building & Construction 6 03-21-2012 12:38 PM
Building Shed roof over deck f8lyer8s Building & Construction 3 07-17-2010 12:13 PM
Building a shed under my deck. stevez Building & Construction 9 04-29-2009 10:19 PM
Building rafters for small shed simonb Roofing/Siding 4 07-15-2008 01:32 PM
building a shed on a sloped hill tom1st Building & Construction 5 08-03-2006 08:22 PM
