Building platform for indoor putting green
Hi all, new to the boards and I'm excited to browse around the site...
I'm building a putting green in my basement that I want to put up on a platform, sized 10' x 18'. My plan is to frame the platform with 2x4s and top it with 1/2 inch particle board.
But, I have a couple questions. One, is the particle board strong enough to handle people walking and putting their weight on it? Being indoors, it would never get wet. And second, if so, how far apart should I space the 2x4's for support? I would suppose there could be guys that weigh as much as 250, 300 pounds on the "green."
My thought was spacing the supports 18" apart, but I didn't know if I could get away with wider spacing, or need to go closer together with the particle board, or if plywood would be more supportive and allow for less cross braces.
Thanks in advance!
EDIT: I probably should have mentioned, the platform will sit directly on the concrete floor.
