Building Permit And Approval For Partial Completion - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-03-2014, 09:31 PM   #1
Rewards Points: 244
Building Permit and approval for Partial Completion
Hi All,
I am trying to finish my basement, but I don't have the fund to complete everything at one time. My plan is to finish it in phases. (e.g. phase 1 - framing, electrical, and plumbing, phase 2 - drywall and fixtures, etc.)
Is it possible to apply building permit for phase 1 and get the framing, electrical, and plumbing approved without actually totally complete the basement?
Of course I will have to reapply the permit again when I am ready with phase 2.
Thanks!
325_man is offline   Reply With Quote
Old 05-03-2014, 09:36 PM   #2
Rewards Points: 1,010
As you frame the question, no. To final a plumbing or electrical permit requires the fixtures to be placed. This is generally precluded without drywall.
Most permits are for 18 months, and you can renew them for a number of times. That course would probably be better
Anti-wingnut is offline   Reply With Quote
Old 05-03-2014, 09:50 PM   #3
Rewards Points: 6,652
It really depends on your area. In mine it would only be if I plan on covering all of the pipes, walls, electrical. That you only need a permit for.
Old 05-03-2014, 09:51 PM   #4
Rewards Points: 244
Thanks for the input Anti-wingnut!
For electrical, I plan to put temporary light fixtures (not decorative ones), electrical outlet, etc.
For plumbing, I will put the pipes to the correct location and cap them without fixtures.
No drywall - that is probably phase 2.
Old 05-03-2014, 09:56 PM   #5
Rewards Points: 244
I am moving plumbing rough-in pipe for the basement bathroom. So, I know I need permit there.
Old 05-04-2014, 10:57 AM   #6
Solutions (handyman)
Rewards Points: 364
renovation
It depends on where you live. It also depends on whether you are doing asll the work yourself or bringing someone else into the picture. The permit is to ensure you or a contractor know what to do ... by code. There is more to plumbing than just running the lines. (proper slope, traps, venting, etc.) Same with electrical. Proper type of wire, number of outlets per run, breaker size, etc. all have to be considered. In my area, the permit is the first thing to get and an extension can be added, if need be. Do it right the first time or it may cause extra cost and headaches.
Mark Harvey is offline   Reply With Quote
Old 05-04-2014, 07:36 PM   #7
Rewards Points: 244
Thanks for the comment, Mark Harvey!
I live in Prince William County, VA. I am doing it myself and I do know what I am doing.
Can you please clarify what you say below, specifically an "extension"?
It is my understanding that a building permit is a 'must' to work on the house. Then, depending on what I am working on, then a permit (e.g. electrical, plumbing, or mechanical) is requested with the building permit.
The problem is that in my county, a current code that govern the bulk head height in Prince William County that states "Beams and girders spaced not less than 4’ (1219mm) on center may project not more than 6” (152mm) below the required ceiling height (i.e. 7')." is changing this coming July where even the bulk head height must be 7'. If this code takes affect, my basement will never be finish able. So, I've been talking to an inspector and his advice is to submit all permit (i.e. building, electrical, plumbing, and mechanical) at the same time by July. All permits will expire in 6 months unless there is 'activity'.
So, This changes my plan. This will speed up the schedule.
Old 05-05-2014, 11:26 AM   #8
Rewards Points: 626
Most permits go like this framing inspection electical and plumbing for ok to insulate. Then insulation inspection to get OK to cover. then sheetrock inspection before any mud is ever applied, then the final inspection to make sure fiixtures work.
Nailbags is offline   Reply With Quote
Old 05-05-2014, 10:08 PM   #9
Rewards Points: 244
For the final inspection, will the room needs to be ready for live-in, or can it not 100% finish in case I run out of fund but yet still get their approval?
Old 05-06-2014, 12:56 AM   #10
Rewards Points: 626
Were I live and work this is what is required passed framing inspection passed electrical and pluming isulation inspection and sheetrock hung and inspecteced a working toilet working sink a safe place to store and prep food. done. no flooring no trim no paint no mud and tape no wall covering electricle fixture working i.e. exsaust fans, lights outlets. covered and working. so check with your building dept.
Pergola - can you believe what the building inspector told me Italgrl Building & Construction 35 09-05-2014 12:00 PM
Built without permit - want city approval now GBunny Building & Construction 11 11-10-2013 08:39 PM
Container homes, what foundations does it need?? shabba1985 Building & Construction 27 03-08-2012 12:48 AM
Progress on Storage building, more slab questions. J S Machine Building & Construction 18 05-07-2010 07:30 AM
