Building A Pergola - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-23-2008, 01:12 AM   #1
Building a Pergola
Hello,
I'm about to build a 14 x14 ft pergola using 4 4x6 post, 15 2x8x16 PT wood. I'm concerned the overall weight. I want to attach 4 2x8x16 to the posts and notch the other 11 2x8x16 and attach 2x2 on top. Will the 4 4x6 post hold the weight or do I need to add more post.
Bingo757 is offline   Reply With Quote
Old 10-26-2008, 03:11 AM   #2
Rewards Points: 1,016
Here is how I did mine on 4x4 posts - wider spacing of doubled 2x6 with 2x2's on top.
Old 10-26-2008, 04:07 PM   #3
Its nice Thanks
Old 10-26-2008, 11:10 PM   #4
Structural Engineer
If the the pergola is going to be attached to another structure, like the one pictured above, then you're good. If its not attached then I would have some concern about the overall structure racking. However this is easy to fix by adding 4x6 knee braces at 45 degree angles to each post (example below). They'll only need to be a couple feet long to add a great amount of lateral stability to the structure.
wildcat is offline   Reply With Quote
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 12:19 PM
Pergola - paint or stain - then maintenance woodsglen Painting 2 07-15-2008 08:30 PM
Building a movable garden shed/greenhouse gardener Building & Construction 1 06-13-2008 04:47 PM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 04:24 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
