Building Partition Wall Behind Base Cabinets - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-09-2010, 05:39 PM   #1
Rewards Points: 260
Building partition wall behind base cabinets
I'm trying to extend my kitchen out into an adjacent living area. There are no walls in the area. I'm debating on whether to build a partition wall behind the base cabinets or just using wood that matches the cabinets. I was thinking about just going with a wall with plaster veneer (drywall with hard coat). This will make my electrical connections easier to run. I need to put a couple outlets in the partition wall.
My brother had custom cabinets installed with matching wood backing. They offset plywood squares and used trim pieces to create a picture frame look. They also added other custom features to it. They actually still built a wall to attach all of this to. This was probably due to the drain pipe and water lines coming up from the slab. Should I build a partition wall behind the cabinets? Would it be possible for me to purchase wood and try to match the stain for the cabinets? I could try to match the custom look of my brothers cabinets. I haven't decided on the finish. I'm leaning towards a maple wood stained to a dark color.
bluefitness is offline   Reply With Quote
Old 11-09-2010, 07:22 PM   #2
Rewards Points: 1,574
Where in your picture do you want the partition wall? You could always mount outlets in the back side of the cabinets without building a partition wall. Usually cabinet mfgs can sell you wood panels that match the color/wood of your cabinets. This could be applied to the back of your cabinets or they may offer some type of panel for the same effect. May be cheaper to build the wall if you finish it with drywall and paint it but the mfg covering would likely look more professional and stylish.
bob22 is offline   Reply With Quote
Old 11-09-2010, 07:34 PM   #3
Rewards Points: 260
The wall would be under the countertop where the seating area is. The countertop will overhang the back of the cabinets by around 12 inches. They were willing to sell me panels that go on the back side. They will be just plain wood panels. There wouldn't be any trim. My other option would be to use birch plywood or find some other type of paneling and just stain it to match the cabinets. I don't know how well that would work out.
Old 11-09-2010, 07:49 PM   #4
jlhaslip's Avatar
Rewards Points: 994
The eating bar would be stronger with a wall there.
And you could still finish it with those panels or paint.
Eating bars can be at 36" (counter height) or at 42" (raised eating bar).
Don't forget to size the counter top accordingly.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
In The Process Of Building My Very First Small Retaining Wall ricksample Landscaping & Lawn Care 3 03-19-2010 10:19 PM
Painting Kitchen Cabinets, Back wall NewlywedKristin Interior Decorating 12 03-18-2010 11:23 AM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Ceiling support for partition wall? hohadcr Carpentry 5 09-28-2009 09:38 PM
has anyone used wall cabinets as base cabinets? 1655graff Carpentry 5 11-18-2008 12:46 PM
