Building A Home - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-28-2011, 01:40 AM   #1
Building a home
Just found this site. like it a lot so far. anyways, We want to build a new home here in Iowa. we are torn between "stick built" & modular. I just want someone to "close in" (frame, sheet, shingle, windows) the stick built, and I would do the rest or sub it out myself. I think I could do this cheaper than goin modular. Any ideas/comments would help.Thanks
timmer98 is offline   Reply With Quote
Old 03-28-2011, 06:11 AM   #2
Stay-at-home GC
By modular, are you referring to most of the mechanicals being completed off-site plus interior finishes, or are you thinking "panelized", having the framing done off-site and then stood up on the foundation?
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 03-28-2011, 07:09 AM   #3
Rewards Points: 150
The area where you want to live, "Iowa" tells it all. You want a house to be able to stand up against the weather which I'm under the opinion can be pretty brutal. I'm thinking 2x6 exterier walls with 1 1/2 inch thick insulation panals on the outside, with rolled insulation between studs. Its when you look at that fuel bill and say I could be buying a new car with that kind of money. Keep in mind with thicker walls, the building industry like doors and window makers are built for 4 inch walls , but you can make them work. Think warmer ,not cute.
bernieb is offline   Reply With Quote
Old 03-28-2011, 08:39 AM   #4
Rewards Points: 3,130
Will you need a loan to build this house? If so, you'll likely need a licensed general contractor's name on the contract (unless you are one). Otherwise, it could be very difficult to get a loan.
Sometimes you can find a licensed gc who will "lend" his name and let you do some or all of the work.
Advice on building a backyard studio/office? johnnyb10 Building & Construction 11 12-03-2011 11:43 PM
History of Lomonaco's Iron Concepts & Home Decor John Lomonaco Introductions 0 11-08-2009 10:39 AM
Building my fisrt home need some input. NHERal Building & Construction 3 03-24-2008 09:42 PM
sewage building code for home owners aokss Plumbing 9 09-11-2006 06:37 PM
