Building A Gazebo - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-10-2014, 10:29 AM   #1
Rewards Points: 160
Building a gazebo
I was looking at options for a gazebo to put on my large ground level deck. The temporary ones seem too flimsy and the pre-built ones are too expensive, so I am considering building my own. Since there's already the deck flooring in place, can I just cut holes into the decking and put the 4x4 supports into the ground set in concrete? Or should I attempt to just build a freestanding structure that sits directly on the deck? A square shape seems much easier to create than a circular one.
matt151617 is offline   Reply With Quote
Old 02-17-2014, 05:39 PM   #2
Rewards Points: 160
Does anyone have any good ideas?
Old 02-17-2014, 05:46 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
I think that most jurisdictions that you would deal with (Building departments) would want you NOT to put it on the deck itself. The load of a new structure was not originally designed for the deck.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 02-17-2014, 05:52 PM   #4
Civil Engineer
Rewards Points: 4,686
You really should check in with your local building inspector. As Andy indicated, they can be very particular about what you put on your deck. If you plan to support the gazebo via posts set on the ground, they will likely need a concrete footing with a standoff bracket (such as the type Simpson makes) to support the posts, but again your building inspector will no doubt have some ideas.
Old 02-21-2014, 03:18 PM   #5
Rewards Points: 256
I would stay away from octagon shaped gazebo. Its not a fun diy project.
JustinK is offline   Reply With Quote
Re: old buildings RWolff Building & Construction 157 01-19-2014 12:35 AM
Putting a hot tub inside our gazebo mvansach Building & Construction 13 02-07-2013 10:59 AM
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
Running electric to gazebo zackray Electrical 10 03-24-2012 11:10 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
