Old 06-13-2012, 02:24 AM   #1
Building a garage - will anything be looked at?
My buddy wants a garage and plans to get a permit for it. No plumbing or electrical, just a big metal building to park his car.
Is there any reason they would want to look at anything inside the house, or inspect anything but the slab and garage?
tibberous is offline   Reply With Quote
Old 06-13-2012, 06:35 AM   #2
There's no reason I can think of.
There only job is just to make sure your doing things right with the project at hand.
There has to be something up in the house if your asking this question.
Old 06-13-2012, 07:05 AM   #3
Only the work listed on the permit can be inspected. None of the unpermitted work done in the house can be looked at
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
oh'mike (06-13-2012)
Old 06-13-2012, 10:53 AM   #4
JOATMON
ddawg16's Avatar
Fixed it for you......
But note....if something is in plain view and is an obvious violation....he can get him for it....
The bigger worry is if he ever decides to sell the house....smart buyers are now checking to see if improvements were permitted....if not, they can back out of a contract or use it as leverage to get the price down.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 06-17-2012, 08:06 PM   #5
Not where I live. A friend of mine had the inspector out for a final on a deck he built. It passed, but while the inspector was there, he took a look at the fence, which was built under a permit a few years ago and passed the final at that time. Some of the fence boards had shrunk enough that the gap between them was no longer to code. My friend was told he had to fix it.
Old 06-17-2012, 08:59 PM   #6
Since when is there a code on gaps in a fence, unless it's around a pool.
One reason I space mine at 3-3/4 not the full 4".
mae-ling (06-17-2012)
Old 06-18-2012, 09:36 AM   #7
The fence IS around a pool.
Old 06-18-2012, 09:50 PM   #8
Usually, when seeking a permit, the authorities will check your plan for the building's location on the lot. There are various restrictions in my city about building height, distances from property lines, distance from the main building, etc. They'll let you know at the plan checking phase of your project whether or not your building is in violation of one of their ordinances.
RM575 is offline   Reply With Quote
Old 06-18-2012, 10:19 PM   #9
With most codes the code in effect at the time of issuance of the building permit prevails throughout the life of the building, except, that current property maintenance and fire code provisions will apply. e.g. smoke detector and carbon monoxide detector requirements. Your municipality may interpret the code to require an inspection of the existing building for smoke and CO detectors when you pull a permit. Additionally some codes require that the dwelling come up to current standards when an alteration or addition is performed e.g. hard wired interconnected smoke detectors. An attached garage is an addition, ask how they view the detached garage.
TheCamper is offline   Reply With Quote
The Following User Says Thank You to TheCamper For This Useful Post:
1910NE (06-19-2012)
Building a garage thaynes Remodeling 11 02-24-2012 07:45 AM
Building Garage overhead Storage swenard Building & Construction 15 01-23-2012 03:01 PM
Old Building problems jake62 Building & Construction 5 08-20-2010 09:32 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
building a garage loft-load question coreyf7 Building & Construction 1 09-07-2009 03:43 PM
