Building Garage Overhead Storage Shelves - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 02:03 PM   #1
I have a two-car garage. I saw a video on the DIY site. It was 30 seconds long and wasn't very informative, but did give me the idea to go forward with it. I used Power Point and tried to make up a basic breakdown of the project. I've attached a pic of one side of the garage. I am planning six shelves in total. over the garage doors will have two 48" shelves that are 24" deep and 21" tall. The torsion bar is just over 21” from the ceiling, that’s how I came up with the 21” height. The center support for the garage door opener belt drive is in the middle. That’s why I chose to make two 48” shelves as opposed to one 8’ shelf. thee 6' shelves will be on the side walls over the garage door rails. Those can be 24" in height as they only need to clear the rails. Here's what I have so far. I'm looking for the exact names of the corner braces they use in the video as well.
http://www.diynetwork.com/how-to/bui...elf/index.html
Building Garage Overhead Storage Shelves-garage-shelvesr.jpg   Building Garage Overhead Storage Shelves-slide1.jpg   Building Garage Overhead Storage Shelves-slide2.jpg   Building Garage Overhead Storage Shelves-slide3.jpg
ragman1171 is offline   Reply With Quote
Old 01-23-2012, 04:37 PM   #2
firehawkmph's Avatar
Rewards Points: 1,902
Ragman,
didn't analyse all your drawings, just wanted to say to leave yourself a couple of inches of space over the drums and springs on your torsion bar assy. When the cables and/or springs break and need to be replaced and wound, a little space is needed. Those metal brackets don't ring a bell, but check with somebody like Simpson who makes a whole catalog worth of metal brackets.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-23-2012, 04:41 PM   #3
Thanks for the info. Maybe I can come up with a removable section over those so I fan keep as much space as possible.
Old 01-23-2012, 05:27 PM   #4
Registered User
Rewards Points: 526
You probably already check the trusses/ceiling joist/ engineered joists up there? Be wary when bolting additional loads on the existing structure...
Gary
Old 01-23-2012, 08:06 PM   #5
I have a good friend who knows more about it than me give me the go ahead on the joists.
Old 01-24-2012, 09:55 AM   #6
I am going to try to take pics along the way and post them up. Either as I go or when I'm done. I really want this to turn out well and be able to pass on my experiences to help them as well.
The Following User Says Thank You to ragman1171 For This Useful Post:
mae-ling (01-24-2012)
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Close to building my garage. Need help on framing a roll up door, some other things. J S Machine Building & Construction 0 01-06-2011 06:50 AM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Building garage with elevated concrete floor dmj245 Building & Construction 13 05-31-2006 04:13 AM
