Building Free Standing Pergola Over Existing Deck, Need Some Help... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-08-2013, 12:19 PM   #1
Dork Fish's Avatar
Building Free standing Pergola over existing deck, need some help...
Hi everyone,
The kind people over in the painting section have graciously helped me out in re-staining our deck. I hoping that some of you could help answer some questions about a pergola.
We would like to build a pergola over our existing deck. It will need to be free standing. I guess my first question would be will this need to have footings or could it be attached to the joists?
We are going to be replacing the decking on our deck so digging footings (if we have to) shouldn't be a problem.
I think the size is going to be either 10 x 10 or 10 x 12.
Here are a few pics of our deck(s) We are wanting the pergola on the deck that is next to the house.
Building  Free standing Pergola over existing deck, need some help...-img_7658.jpg   Building  Free standing Pergola over existing deck, need some help...-img_7659.jpg   Building  Free standing Pergola over existing deck, need some help...-img_7660.jpg
Dork Fish is offline   Reply With Quote
Old 05-08-2013, 05:38 PM   #2
Civil Engineer
Rewards Points: 4,700
This is likely a call by the building inspector, I would start by talking to them. Maybe no permit is required at all, in which case you are free to design the pergola any way you like. Bear in mind that the Chicago area is subject to high wind, so whatever solution you arrive at, make sure the pergola is well anchored, you don't want it becoming a flying missile in a high wind event.
Old 05-09-2013, 06:55 AM   #3
Dork Fish's Avatar
they will probably want a permit then they will raise my taxes...yada yada yada
Old 05-09-2013, 09:07 AM   #4
MJ Force's Avatar
Rewards Points: 150
When your project crashes down on someone, what's cheaper; a ambulance/hospital/liable suit or a few extra taxes and permit?
MJ Force is offline   Reply With Quote
Old 05-09-2013, 09:15 AM   #5
Dork Fish's Avatar
If it is done right? Why would it crash down?
Old 05-09-2013, 09:32 AM   #6
MJ Force's Avatar
Rewards Points: 150
If built properly it won't crash down. No worries.
Old 05-09-2013, 09:41 AM   #7
Dork Fish's Avatar
When pouring the footing, do we embed the 4 x 4 or use a column base like a Simpson CB or CBSQ?
Old 05-09-2013, 10:11 AM   #8
MJ Force's Avatar
Rewards Points: 150
The most important thing for your pergola is that it's properly braced so that it doesn't try to rack or wiggle. 4x4's can still wiggle even when embedded 3' in the ground. A6x6 will wiggle less. With proper bracing it will barely wiggle. High winds could cause your pergola to wiggle slightly or create an oscillating effect which which may cause the joints to fail which may...anyways. Embedded post are only as strong as the substate which surrounds it.
You can add bracing which can be decorative also. If you plan on roofing your pergola you may need a permit.
Old 05-09-2013, 10:27 AM   #9
Dork Fish's Avatar
I was looking to build the one that "The family handyman" featured
http://www.familyhandyman.com/DIY-Pr...uild-a-pergola
Old 05-09-2013, 04:59 PM   #10
GBrackins's Avatar
Rewards Points: 2,108
nice and comes with instructions and materials list ....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-09-2013, 06:14 PM   #11
kwikfishron's Avatar
Rewards Points: 414
Can't say I've ever seen that detail before.
kwikfishron is online now   Reply With Quote
Old 05-09-2013, 06:30 PM   #12
GBrackins's Avatar
ya gotta breath ....
Gary
Old 05-09-2013, 06:34 PM   #13
Rewards Points: 414
Okie Dokie.
Old 05-10-2013, 10:29 AM   #14
Dork Fish's Avatar
Wait, what do you mean by that? Are you being sarcastic? :/
Old 05-10-2013, 10:31 AM   #15
Dork Fish's Avatar
This part... See prior post
Deck building around pool Ineedhelp2009 Building & Construction 9 03-30-2013 01:40 PM
Please Help With My Existing Deck piper131 Building & Construction 23 07-13-2012 06:21 PM
Adding support for new hot tub on an existing deck. hammerandnail Building & Construction 8 07-04-2012 06:55 PM
Pergola Attached to Second Story Deck kaalapurushha Building & Construction 4 06-19-2012 10:32 AM
Can Deck Posts be fixed to existing rock? drcieslak Building & Construction 3 08-03-2011 04:35 PM
