Building A Firepit - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-11-2013, 08:39 AM   #1
Rewards Points: 97
Building a firepit
I have a large backyard and we have decided to put in a firepit. We have a fence and have isolated a corner of the yard as the ideal location for said firepit.
Our plan is to build the firepit in the center of what will become a 14'x14' paver patio
What kind of clearance should we maintain from the fence and also mulch/shrubs we plan on putting between the corner of fence and the patio
BigRedFan is offline   Reply With Quote
Old 05-11-2013, 08:45 AM   #2
Rewards Points: 97
Here is the very crude drawing I worked up
Old 05-11-2013, 10:28 AM   #3
Old School
Willie T's Avatar
Make it a gas-fired pit, and don't worry about clearances, nor about smoke or cleanup of the ashes.
Willie T
Old 05-11-2013, 02:44 PM   #4
Rewards Points: 97
I had been thinking about that just have no idea what a plumber would charge to run a nat gas line
Old 05-11-2013, 02:55 PM   #5
Rewards Points: 13,968
One way to find out is make the call.
May lower the price of you dig the ditch.
Old 05-11-2013, 05:38 PM   #6
Old School
Willie T's Avatar
Run it off a small propane tank, and you just have to string out your own rubber hose for ten feet, or so.
Willie T
Old 05-12-2013, 09:19 AM   #7
Rewards Points: 236
I
i would leave enough room to get back there and do whatever may pop up.
Fix'n it is offline   Reply With Quote
Old 05-12-2013, 09:48 AM   #8
Rewards Points: 166
Disagree with gas firepit. Wood in a fire pit is the way to go. Be a man!!!
Minus08 is offline   Reply With Quote
Old 05-12-2013, 11:44 AM   #9
Rewards Points: 40
If you go with wood it might be wise to check with your local fire department. They can advise you if a wood fire is legal, and what set back distances to use in your area.
daveb1 is offline   Reply With Quote
Old 05-12-2013, 12:19 PM   #10
Rewards Points: 97
Think I am going to buy one of the square tables with the propane tank stored in it. For how much it will be used. I imagine a couple times per month seems like the most economical
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Siding on utility building Angela3511 Building & Construction 5 04-18-2011 07:28 PM
Steel freespan building with interior office build out viper Building & Construction 4 01-16-2011 07:31 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
