Building A Fire Pit On Wood Deck ?'s - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-14-2011, 03:34 PM   #1
Building a fire pit on wood deck ?'s
I'm starting to plan out my deck and want to put a masonry fire pit on it. I would like to build it on top of the deck. Is there a way to insulate it from the wood, or would there be enough stone that it wouldn't matter?
Jeff213 is offline   Reply With Quote
Old 05-14-2011, 03:38 PM   #2
Old School
Willie T's Avatar
Smarter to build it through a big hole in the deck... with an air gap between the stone and the wood. But it really boils down to your local codes. Ask the Building Official.
Willie T
Old 05-14-2011, 03:42 PM   #3
OK. I was just wondering because the deck is about 6' off the ground. I didn't know if there was enough heat that would be transferred through for it to be a problem.
Old 05-14-2011, 03:45 PM   #4
Old School
Willie T's Avatar
They do make metal pan type liners that can be hung from a hole in a deck like that..... or just elevated above the wood with plenty of ventilation below.
Willie T
Old 05-14-2011, 05:08 PM   #5
Carpenter
dtsman's Avatar
You can use something like this.
http://www.dancingfire.com/chimineas-deck
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Old 05-14-2011, 09:39 PM   #6
Rewards Points: 5,336
Is it just me or is putting a fire pit on a wood deck, next to a house seem like a marginal idea?
Have you asked your insurance carrier about coverage on this?
Ron
Old 05-15-2011, 01:27 AM   #7
I found these as well:
http://www.ufpi.com/product/latitude...deckstones.htm
oatlord is offline   Reply With Quote
Old 05-15-2011, 08:11 PM   #8
cut through the deck, you dont have to pour a complete slab under it, just a perimiter footing and leave the middle soil and put about 6 inchs of gravel in it for drainage so the rain dosnt fill it up with water. make sure you bring the sides up about 8 inches from the deck or higher. this really isnt a good idea to put in a deck that is attached to the house though. without a spark screen its a recipe for disaster.
good luck
brick_layer is offline   Reply With Quote
Composite vs wood deck screws cranedk Building & Construction 6 11-26-2015 03:47 PM
Any wood prep product for cracks in deck wood? FrankL Painting 1 06-11-2010 11:20 AM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
New Trex Deck just installed with wood deck screws instead of composite- HELP PLEASE! JLayman Building & Construction 3 08-07-2009 10:20 PM
Worst part of building a deck?? Ler0y Jenkins General DIY Discussions 8 06-09-2008 03:07 PM
