Old 06-20-2008, 12:43 AM   #1
PHT
Building a fence
I am attempting to build a wood fence. My problem is that I need to use an existing metal pole (to secure post or pole) that is flush against my neighbors concrete footer that surrounds the base of his house. He does not want me to dig next to his house, so I am trying to figure out how to secure a larger pole over it. Any advise would be be appreciated. I have photo. Thanks
PHT is offline   Reply With Quote
Old 06-20-2008, 07:06 AM   #2
Building a fence
Can you post a pic?
HandyMac is offline   Reply With Quote
Old 06-20-2008, 08:13 AM   #3
47_47's Avatar
Building a fence
What is the set back from the property line for the type of fence you plan on installing?
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Old 06-20-2008, 08:33 AM   #4
bofusmosby's Avatar
Building a fence
Can you "sleeve" the metal post by building a wood frame around the metal pole?
bofusmosby is offline   Reply With Quote
Old 06-20-2008, 08:46 AM   #5
Moderator
Termite's Avatar
Building a fence
If the post is very close to the house you could cut a dado in the wood post to accomodate the metal post (surrounding the metal post on three sides). The dado could be formed with a series of several lengthwise cuts with a circular saw about 1/8" apart, and some chisel work. Three or four bolts or self-drilling metal screws could be used to secure the wood post to the metal post.
Old 06-20-2008, 02:58 PM   #6
PHT
Building a fence
Having trouble uploading pic. Thanks everyone for the great advice. I am going to try bofusmosby's idea and "sleeve" it. This is a great forum!
Old 06-20-2008, 06:04 PM   #7
Building a fence
did it work out?
kshankle is offline   Reply With Quote
Old 06-20-2008, 09:19 PM   #8
PHT
Building a fence
It did work out great! The pole is an ancient 2 1/4" filled with concrete set in a concrete footer. The pole is flush against my neighbors concrete footer that surrounds the base of his house. It is solid! I sleeved it in with four 1x4x8 which I precut, cutting one board shorter to rest on the house footer, then boxed it in and reinforced with 1-5/8" deck screws. I secured the backboard and sides first, then dropped it down onto the pole and closed it up with the outside board. I prepainted both sides of the boards anticipating that it would be impossible to do once the post was built. I may fill it with concrete mix to stabilize it.
Old 06-21-2008, 08:18 AM   #9
bofusmosby's Avatar
Building a fence
Glad it worked for you. Remember, where there's a will, there's a way!
labor cost for building a fence clintb44 Off Topic 4 08-18-2010 03:25 PM
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 04:39 PM
Height of Fence = Height of Posts Necessary Dallas Building & Construction 2 11-05-2007 10:47 AM
Fence problems-Cement or No Cement WBMill Landscaping & Lawn Care 8 06-17-2007 03:36 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
