Old 07-22-2009, 12:00 PM   #1
Talking
Building on existing concrete slab
We have a concrete slab we originally intended to use for a dog kennel. However, we have now decided to use it as the foundation for a shed. How do I go about attaching the walls to the foundation?
JimSpokane is offline   Reply With Quote
Old 07-22-2009, 12:33 PM   #2
Moderator
Termite's Avatar
Provided it is small enough that your city doesn't require frost footings, the walls can be attached using various types of wedge anchors. If code isn't applicable you could use something less substantial such as tapcon screws.
Old 07-22-2009, 02:19 PM   #3
Thanks for the info
Tags
existing concrete slab, new building
building shower walls with concrete canyongirl Building & Construction 13 03-14-2010 01:44 PM
concrete grade/bond beams under slab? jklingel Building & Construction 7 12-22-2008 01:43 PM
Carpet on a sloped concrete slab? slickracer Flooring 4 12-13-2008 04:08 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
