Building On Existing 4" Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-12-2013, 05:47 PM   #1
Building on existing 4" slab
Hello to all first timer here!
I have an existing 10'X14 'floating cement slab only 4" thick though out, reinforced with wire, with some sand add for a base. I would like to build a shed/yard tractor garage the same size on it here in Michigan.
My questions are:
6" Blocking on top of slab around perimeter ? or
Dig around & under perimeter for more thickness & some sort of footing than place blocking on new pour at outer perimeter ?
There is a existing 10'x10' shed on the slab now with its own wood flooring that will be removed & I don't think there is any cracks in the slab.
I would like to think that just mortaring & using re-bar the 6" blocks on top around the perimeter would be fine for such a small build.
Any input would be helpful.
workdog is offline   Reply With Quote
Old 09-12-2013, 05:52 PM   #2
Rewards Points: 14,300
Should be fine to just add the block on the slab for that small a building.
There's just no way to dig out for a proper footing once the slabs been pored.
Good Idea to add a row of block though to get the siding up off the slab and above grade.
Old 09-12-2013, 07:50 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,328
some rebar into the slab wher the block is would be a good idea to tie it togehter
woodworkbykirk is offline   Reply With Quote
Old 09-14-2013, 07:59 PM   #4
Thanks Joecaption thinking the same, might even add other course of blocks.
Pouring new concrete around existing slab on grade. Supercontinent Concrete, Stone & Masonry 1 06-19-2012 11:20 AM
Need help setting shower drain in existing slab drain hole! deedeedeeIY Kitchen & Bath Remodeling 9 05-11-2012 09:39 AM
New construction on existing steel building burton Building & Construction 6 03-30-2010 03:22 PM
Best way to attach low level deck to existing concrete slab. fulghumd Building & Construction 4 03-11-2010 06:45 PM
Building on existing concrete slab JimSpokane Building & Construction 2 07-22-2009 01:19 PM
