Old 10-25-2009, 01:27 PM   #1
bsfisher's Avatar
building a door jamb w/2x6 stock ???
I'm building a 12x12 shed (with 6'3" high side walls) and I'd like to just put in one steel entry door. I purchased a VERY GOOD 36" steel entry door from our Local Habitat Restore place for only $12 with NO door jamb. I need to reverse the hinges becasue I want the door to swing out instead of swinging inside to avoid hitting my 2nd rafter and to give me more working room inside. I know I can buy a 36" jamb kit at lowes for around $70 but I was wondering if I can just put this door in a 2x6 frame (top & both sides) and just purchase the 36" entry sill on the bottom of my 2x6 door jamb? and do I leave a 1/16 or 1/8 around the top,bottom and strike plate sides and install 1x for the door stop and magnetic weather seal etc... has anyone done this with 2x6 stock or know of a site with pics? I know 2x6 is beefy but I'm a beefy kinda guy
bsfisher is offline   Reply With Quote
Old 10-25-2009, 02:50 PM   #2
Super Moderator
Why not?
If you have a table saw you could do a one piece jamb like the store bought ones.
Framing lumber is not very rot resistant,prime all sides and paint well.
Old 10-25-2009, 04:34 PM   #3
bsfisher's Avatar
why not even use treated 2x6, no priming or painting required, will outlast the whole structure and I can stain/seal it next year when I stain/seal my new deck. Even use a treated 2x6 for a threshold and put a bevel on it
Old 10-25-2009, 04:41 PM   #4
Super Moderator
They shrink to much,Treated thresh might work.
Old 10-25-2009, 04:56 PM   #5
bsfisher's Avatar
Ohhhh yeaaaa....yikes...shrinkage...
a good piece of 2x6 fur or redwood still might be better than pine, correct???
Old 10-25-2009, 05:38 PM   #6
Super Moderator
Oh,Yea.
Old 10-25-2009, 07:53 PM   #7
Moderator
Le3arn all you can, first: http://books.google.com/books?ei=wuP...jambs&as_brr=3
Be safe, Gary
Clothes taking longer to dry?
Advice on building a backyard studio/office? johnnyb10 Building & Construction 11 12-04-2011 12:43 AM
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 01:19 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
