Building Dock On Pond...need Framing Help! - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 10:01 AM   #16
Building docks with 55 gallon barrels isn't new technology, I've just never done it before so asking for advice. Thanks for the input, Jack.
toddtx is offline   Reply With Quote
Old 08-06-2011, 11:49 AM   #17
Indentured Servant
You can buy floating docks. I built a swim raft last summer using barrels. Was going to build a dock too but bought Tommy Dock hardware instead. Glad i did.
jackpine is offline   Reply With Quote
Old 08-07-2011, 02:02 PM   #18
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Sure the barrels will have plenty of buoyancy if they can be sealed tightly. I wouldn't suggest using barrels with removable tops. Not sure they would stay sealed.
Steel drums sealed all around and used for floating docks only had a couple of threaded bung holes to worry about. Don't know about plastic barrels.
XXX
Old 08-07-2011, 02:16 PM   #19
The barrrels I will be using are plastic barrels with two bung holes. I have already removed the bungs and applied silicon caulking for extra insurance. Initially I didn't caulk the bungs so when I removed it to caulk there was actually a little air pressure in the barrel. I had rinsed the barrels out and I assume that due to the high heat the air expanded a bit. If the bungs stay sealed these barrels should last until they dry rot which will hopefully be many years from now.
Old 08-07-2011, 02:50 PM   #20
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Depends on how you nest them into the underside of the structure. Will they support the weight of the structure and occupants without collapsing or blowing out? I don't know.
XXX
Old 01-16-2012, 10:15 PM   #21
I am building a 8x18 dock on an inland lake in ohio. the lake is lowered to do this work and i am thinking of sinking either 4x4 or 4x6 treated wood in concrete at 4.5ft apart? any ideas? all help is appriciated. thanks
micky5587 is offline   Reply With Quote
Old 01-16-2012, 10:39 PM   #22
Rewards Points: 14,020
I lived in NH on Highland Lake for 1/2 of my life and most of the docks up there are all DIY by weekend warriers made out of 4 X 4's. The lake goes from dained in the fall, to over the banks in the spring. In winter there's often 4' of ice on the lake. I've never once seen or heard of the post snapping off. My dads dock with 4 X 4's has been there for 15 years and he did not even set the post in concrete..
But yes a floating dock works fine if you have a way to anchor it. Some people use post at the end on each side set in the ground with a metal band that fit's loosely around the post and bolted to the rim joist. That way the dock stays put, but can ride up and down when the water level changes.
Old 01-17-2012, 01:47 AM   #23
Don't shoot clays over a pond. The clays are toxic and don't go away.
Hardway is offline   Reply With Quote
Old 01-17-2012, 09:26 AM   #24
No matter what you do Mother Nature always wins.
Marvel is offline   Reply With Quote
Old 01-17-2012, 12:53 PM   #25
AGWhitehouse's Avatar
I built a dock with (16) 55 gallon plastic drums. I think it was 12'x16', but I could be off a bit. Didn't caulk the bung holes, just torqued them down tight and they never leaked. The barrels were lined up in two rows of 8 with the bottoms of the barrels pointing towards the sides. There was about 2' between the barrel rows. All I did was create a "skirt" of sorts beneath the deck to hold the barrels in place. That way if I ever needed to replace them I could just jack up the dock and slide them in an out.
For the amount of barrels you need, a 55 gallon barrel will float approx. 440lbs. But remember to account for live loading (walking). If you are too close to the actual usage load it will be like walking really really drunk as the dock will be bouncing all over. With the 16 barrels (7,040lbs)we consistenly had a dozen people on there without ill effect.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 01-17-2012, 12:58 PM   #26
It was an unusual winter condition that took out docks that had been there over 20 years. It even excavated the banks where the ice sheet landed, leaving a dirt birm across the front yards. What happened was a deep freeze that create 8" or so of ice quickly and then a warm patch with rain that thawed the edges off the banks about 10', 30'+ on the shallow area. Followed that up with a windy day with strong gusts that sent the ice sheet into the shallow area banks. Since it had 30'+ to speed up before impact it did some serious damage, included snapping the 8x8 posts on my dock...I'm not surprised you're all surprised, I wouldn't believe it if I hadn't seen it with my own eyes. After that, we built the floater I mention above.
Old 01-26-2012, 10:30 AM   #27
Here is a picture of my dock. I built the 10' gangway with a 2x8 frame and the 10x10 dock with a 2x10 frame(all treated lumber of course). I bought galvanized hardware from dockbuilders.com and was very pleased with their products. I used 14 barrels under the dock leaving a space in the middle open for a livewell in the future and used one barrel at the end of the gangway to reduce the sag from the weight of the dock. You can jump up and down on this thing and it barely rocks.
I augered two holes into the bank at 3' deep and placed 4x6x4 treated lumber into the holes and concreted into place. I then attached a cross member to them with my dock hardware attached.
It has been built for some time now but had to wait for pond to fill to attach the pieces. Now the pond is above full pool so part of the gangway is under water but when the water subsides it should be perfect.
It was a fun project but don't underestimate the weight of the lumber. I had to use a tractor to flip my dock once I had the barrels tied off and even that was a chore.
Good luck and please post pics showing progress and completion.
Building dock on pond...need framing help!-dock2.jpg   Building dock on pond...need framing help!-dock.jpg
Old 01-26-2012, 10:44 AM   #28
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
I've done the 4x4 and the 2x6 and the cross bracing and the barrels and all the other methods you can imagine.
Have you ever taken your 80 year old mom out on that thing?
You can't. They are unstable and a real hazard to walk on.
I finally came to my senses and bought an aluminum dock with removable cedar panels.
My wife and I take it out and put it back in every year.
It's great. Very sturdy and light weight.
tcleve4911 is offline   Reply With Quote
Building a temporary workshop inside of large pole building HandyDave Building & Construction 0 02-17-2010 08:39 PM
Building a storage building / small shop..please step in. J S Machine Building & Construction 35 01-20-2010 12:54 PM
Floating dock walk attachment pookemp Building & Construction 5 01-04-2009 06:48 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
