Building A Deck Without Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 05:05 PM   #1
Building a deck without concrete
Hi. This spring I will be building a new deck around my house. Only problem is that where I will be doing it there is a well, septic, and hydro. So I cannot do concrete. I have seen adjustable post holders and DEK blocks. Will these work? My area also has a lot of heaving in spring.
Darren R is offline   Reply With Quote
Old 02-21-2012, 05:52 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Dek blocks and some of the adjustable posts will not work if you have soils that heave or frost unless the deck is not attached to the house and you can tolerate an uneven deck surface.
What is the problem with drilling some holes (after exploring) and using Sontubes below you local frost levels that are filled with concrete. You then insert and Simpson stand-off bracket to keep the wood above the ground. This is a proven method even for ledger attached deck. The Dek blocks may not be allowed where you are.
Dick
concretemasonry is online now   Reply With Quote
Old 02-21-2012, 07:51 PM   #3
Rewards Points: 4,538
dick, you looked younger next the bugatti
Old 02-21-2012, 08:03 PM   #4
Problem being the well and the septic tank as mentioned. So I need to figure out another way that will allow me to support the deck
Old 02-21-2012, 08:10 PM   #5
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Create a depression, tamp the bottom nice and flat and level, and use patio blocks.
(this is what they are made for)
Post up from there.
Legal in many parts.
titanoman is offline   Reply With Quote
Old 02-21-2012, 08:21 PM   #6
Post up from there.
What's your thoughts on the adjustable posts to adjust if required?
Old 02-21-2012, 08:30 PM   #7
Rewards Points: 768
Where do you live? If your in a climate where the soil freezes/thaws (midwest/northeast, etc.) the only way to support a deck is with footings. Digging would be the only way in that case.
cibula11 is offline   Reply With Quote
Old 02-21-2012, 08:34 PM   #8
Winter peg Manitoba. Frostline is five feet. Do I have to go that deep?
Old 02-21-2012, 08:36 PM   #9
Rewards Points: 768
Yep. I live in Iowa where the frost line is 42", but most guys go to 48" to be safe.
My guess is that if you can't dig 5 feet down where you need to (because of the septic, etc.) then you'll have to come up with a different idea than a deck, like a paver patio.
Old 02-21-2012, 08:42 PM   #10
The only other thing I can think of is to drive piles where I can and build off of that although it would be very expensive. Deep holes here don't work well due to the water in the ground.
Old 02-21-2012, 09:19 PM   #11
Disabled wood vet
titanoman's Avatar
That's fine.
Or use metal shims later if need be.
I think this is your only option, other than pavers.
Pass it by the building department.
They will probably approve it.
Old 02-22-2012, 12:32 AM   #12
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
Take a look at THIS link.
Andy
You can send my payment via Paypal.
That's just a joke.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 02-22-2012, 12:38 AM   #13
Disabled wood vet
titanoman's Avatar
Andy
That's just a joke.
We can charge people?
How accurate do we gotta be to go pro?
Old 02-22-2012, 01:30 PM   #14
Ever hear of ground hogs?
Old 02-22-2012, 07:14 PM   #15
AndyGump's Avatar
Rewards Points: 664
What does that mean?
I guess the link I posted just doesn't work for you?
Andy.
Building deck on side of Gambrel style roof - questions sheslostcontrol Building & Construction 14 05-11-2011 12:15 AM
Building a deck on a concrete patio. Leon H. Building & Construction 9 03-29-2011 04:21 PM
Fastening deck posts to concrete spaceman spif Carpentry 6 10-11-2010 07:09 PM
Is it SAFE not to use deck post concrete anchors? z_zk_z Building & Construction 3 06-28-2010 10:35 PM
Building Deck on top of Roof wombosi Building & Construction 0 10-26-2008 05:26 PM
