Building A Deck On Solid Rock - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-05-2009, 04:04 PM   #1
Building a deck on solid rock
I'm planning to build a wooden deck near a river, problem is that the entire ground is solid rock & its sloped too ( 15 degrees approx). Not sure how to attach my foundation/posts on top of solid rock.
Deck size approx 15' x 25'. Ground level. May tie a boat to it in the future.
Possible ideas:
Rent/buy a rotory SDS hammer drill, drill 1 1/2" hole, about 12" deep, insert 1" diameter stainless steel bolt, (maybe 8” long) then secure bolt in hole with concrete or epoxy. Attach a Simpson 4x4 connector to the bolt & then attach my beam/post to it. With the ground being rock, its unevenness concerns me with this approach, ie... the Simpson adapter would probably not sit flat on the rock.
Or…
Rent/buy a rotory SDS hammer drill, drill a series of 1 1/2" holes, in close proximity, about 12" deep, then use another SDS bit to break the away the rock. Fill hole with cement. Rinse & Repeat for each post.
I've never worked with an SDS hammer drill nor have I ever drilled rock. Can the above methods cause the rock to split/fracture, in return making my foundation weaker??
I'm out of ideas. Any suggestions, info, or links are greatly appreciated.
time2scream is offline   Reply With Quote
Old 03-05-2009, 04:33 PM   #2
Check with your Building Inspector, see what they require
Attached to the house or stand alone?
Location? Frost area?
Old 03-05-2009, 07:08 PM   #3
Stand alone , approx 300' from house. Tennessee
Old 03-05-2009, 07:45 PM   #4
Stand alone is better since you do not have to worry about frost
Of course if the rock is like that it probably won't move
I'd be inclined to drill & use simpson connector
If the connector is lined up right, cut the bottom of the post to match the slope
I'm not sure of the appropriate method for bolting into the rock
For the boat I think I'd tend to drill some other holes & put some separate anchors in
Composite deck building question Big Marino Carpentry 6 12-31-2008 10:14 PM
Building Deck on top of Roof wombosi Building & Construction 0 10-26-2008 04:26 PM
Building a Cabin on Solid Rock thatstaken2 Building & Construction 1 08-11-2008 08:28 PM
Worst part of building a deck?? Ler0y Jenkins General DIY Discussions 8 06-09-2008 03:07 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
