Old 04-25-2009, 08:27 PM   #1
Question Building deck over concrete patio
I currently have a 12 x 24 concrete patio that is cracked parallel to the house, almost in the center. I want to build a deck approximately the same size, in the same location. The problem is that the patio slopes toward the house and water pools up in one of the inside corners against the house.
I was curious to determine ideas regarding whether I should (a) have the deck raised and leveled, by means of a jacking process of some sort, and then build the deck over the repaired patio or (b) have the patio torn out and then fill in the void with dirt and then build the deck over that. I got a quote for having the concrete raised and leveled for around $950. I assume the cost of removing the patio would be about $350 or more, plus the cost of some material to fill in the hole that the removed patio will cost. Could I just repour concrete over the existing patio to fix the poor slope, since I don't care what it looks like, and then deck over that?
Any ideas? I would like to do as much of this as I can myself, and my dad and I will be building the deck.
Thanks for any help.
stro77 is offline   Reply With Quote
Old 04-25-2009, 11:32 PM   #2
I would remove the concrete! The $350 cost is less than what it would cost to level the pad!
Old 04-26-2009, 02:08 AM   #3
Kitchen remodel Guru
A.W. Davis's Avatar
Remove the concrete and be done with it.
doing a great job right......the first time
http://www.awdavisconstruction.com/
A.W. Davis is offline   Reply With Quote
Old 04-26-2009, 06:33 AM   #4
Even if you add concrete to level it, there's no guarranty it won't continue to sink. Even mud jacking might not be the correct decision with all the weight you'll be putting on top after it's raised.
Pull it up.
Ron
Ron6519 is online now   Reply With Quote
Old 04-26-2009, 07:50 AM   #5
And the deck over it may have problems due to no air flow under it. So remove the concrete.
Old 04-26-2009, 08:02 AM   #6
its unamimous - get that old stuff the f outta there compact the new fill to provide positive drainage,,, careful of mechanical compaction in case you've block bsmt walls - could damage 'em !
yesitsconcrete is offline   Reply With Quote
Old 04-26-2009, 08:38 AM   #7
You will have to make holes in it anyhow, to dig for post foundations, remove it.
Old 04-26-2009, 01:11 PM   #8
Thanks folks. I guess that makes the most sense, as then I can grade to flow away from the house, and I won't have to worry about further concrete changes. Thanks again.
Old 06-25-2009, 06:21 PM   #9
tfc
$30.00 for a 10lb sledge hammer. Take out some frustrations on that concrete.
I had the same issue - my patio that came with the house was leaning towards the house. I just hammered on it a hour or so each night after work - very therapeutic!
Then I roughed in a 16x20 deck..! Picture here - http://tfcountdown.blogspot.com/
We even used the old concrete as landscaping - look around the trees in background hehe. It looks nice.
I see this is a older post now - how did it go?
TFC
tfc is offline   Reply With Quote
More On This Topic
Creating an inviting outdoor space by building a patio is a great idea, but can become a great headache if not well thought out. Put together a budget and develop your project plans before getting started and your wallet and home will thank you for it. Read More »
Adding a conservatory to an existing home has become a hot commodity amongst home owners. Not only is it a way to increase living space, adding a conservatory can boost the overall value of a home. Before you get started on your project, however, read... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be taking a look at the grade around our foundation. When checking the grade around your foundation, you want a nice slope to be going away from your foundation so that when it... Read More »
Creating a sound system for your patio can add ambiance to your backyard. A sound system is a way for you to pump relaxing music to your patio or to enhance your party atmosphere with dance music. Wiring your patio with a sound system is a fairly simple... Read More »
Determining where you are going to put a new patio is just the first step in making this addition to your home. After you figure out just where the patio will be, it's time to start prepping for the project. There are a few things to think about during... Read More »
Building a deck on solid rock time2scream Building & Construction 3 03-05-2009 09:45 PM
Building a deck on an inside corner ternstes Carpentry 3 06-16-2008 10:45 PM
deck header over concrete steps and other deck questions bobcatnj Building & Construction 6 05-09-2008 04:54 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 02:17 PM
Concrete Patio Advise (New) dcd22 Building & Construction 4 03-06-2008 12:51 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
