-   -   Building deck over concrete patio (http://www.diychatroom.com/f19/building-deck-over-concrete-patio-43247/)
stro77 04-25-2009 06:27 PM
I currently have a 12 x 24 concrete patio that is cracked parallel to the house, almost in the center. I want to build a deck approximately the same size, in the same location. The problem is that the patio slopes toward the house and water pools up in one of the inside corners against the house.
I was curious to determine ideas regarding whether I should (a) have the deck raised and leveled, by means of a jacking process of some sort, and then build the deck over the repaired patio or (b) have the patio torn out and then fill in the void with dirt and then build the deck over that. I got a quote for having the concrete raised and leveled for around $950. I assume the cost of removing the patio would be about $350 or more, plus the cost of some material to fill in the hole that the removed patio will cost. Could I just repour concrete over the existing patio to fix the poor slope, since I don't care what it looks like, and then deck over that?
Any ideas? I would like to do as much of this as I can myself, and my dad and I will be building the deck.
Thanks for any help.
Wildie 04-25-2009 09:32 PM
I would remove the concrete! The $350 cost is less than what it would cost to level the pad!
A.W. Davis 04-26-2009 12:08 AM
Remove the concrete and be done with it.
Ron6519 04-26-2009 04:33 AM
Even if you add concrete to level it, there's no guarranty it won't continue to sink. Even mud jacking might not be the correct decision with all the weight you'll be putting on top after it's raised.
Pull it up.
Ron
Bob Mariani 04-26-2009 05:50 AM
And the deck over it may have problems due to no air flow under it. So remove the concrete.
yesitsconcrete 04-26-2009 06:02 AM
its unamimous - get that old stuff the f outta there :laughing: compact the new fill to provide positive drainage,,, careful of mechanical compaction in case you've block bsmt walls - could damage 'em !
Just Bill 04-26-2009 06:38 AM
You will have to make holes in it anyhow, to dig for post foundations, remove it.
stro77 04-26-2009 11:11 AM
Thanks folks. I guess that makes the most sense, as then I can grade to flow away from the house, and I won't have to worry about further concrete changes. Thanks again.
tfc 06-25-2009 04:21 PM
$30.00 for a 10lb sledge hammer. Take out some frustrations on that concrete.
I had the same issue - my patio that came with the house was leaning towards the house. I just hammered on it a hour or so each night after work - very therapeutic!
Then I roughed in a 16x20 deck..! Picture here - http://tfcountdown.blogspot.com/
We even used the old concrete as landscaping - look around the trees in background hehe. It looks nice.
I see this is a older post now - how did it go?
TFC
