Building A Deck/Balcony With Diagonal Supports - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-03-2011, 01:40 PM   #1
Building a Deck/Balcony with Diagonal Supports
I need to build a deck or balcony above my garage door, without any vertical supports (risk of having them banged up by car).
Dimensions are 108 inches width, and depth is 54".
Attaching a 4x4 post to each side of garage door, with bolts going clear through the cinderblock.
Then, attach (with bolts through) diagonally, a 2x8 to each side of the post (total of 4 diagonals - 2 on each post x 2 posts), at a somewhat steep angle. These would be the only supports.
Overhang (past the diagonals) will be about 15"
Joists (2x8) - spaced 16" to be attached with metal hangers to perpendicular floor beams
Or.... do i need to first attach a ledger and then attach the joists to the ledger?
Thanks for any help or guidance you may provide
ms778899 is offline   Reply With Quote
Old 07-03-2011, 02:22 PM   #2
Framing Contractor
Call an architect or engineer and have them figure it out. Then provide the plans to your building department for permits and inspections.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 07-03-2011, 05:51 PM   #3
Too Old
Get a permit on this. It sounded like it could work until you asked about the ledger.
havalife is offline   Reply With Quote
Old 07-04-2011, 08:10 PM   #4
ledger
thanks
my idea was to attach the joists pependicular to the last floor beam. i think this would be stronger than attaching them to a ledger. huh?
Steel freespan building with interior office build out viper Building & Construction 4 01-16-2011 08:31 PM
Close to building my garage. Need help on framing a roll up door, some other things. J S Machine Building & Construction 0 01-06-2011 07:50 AM
Getting around building codes; shotcrete; LOW cost shotcreteman Building & Construction 28 10-15-2010 06:40 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
45 Degree balcony supports rickr01 Building & Construction 5 09-12-2005 12:10 PM
