Building A Deck Above A Work Area In My Barn - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-12-2012, 07:21 PM   #1
building a deck above a work area in my barn
If I use 6 x 6 treated posts 20' long as beams and have them spaced 12' apart. Can I use 2 x 12 joists at 16" spacing to build a deck? If so how much weight would the floor support pr sq foot and would I need to use posts in the center of each beam?
Last edited by Larion Swartzen; 11-12-2012 at 07:24 PM. Reason: some words were added accidently
Larion Swartzen is offline   Reply With Quote
Old 11-12-2012, 09:52 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the forum!
I'm not following .... 20' long beam and 12' spacing of post seems you'd come up about 4' short on your beam
I'd suggest checkin' out the American Wood Council's "Prescriptive Residential Wood Deck Construction Guide" based upon the requirements of the 2009 International Residential Code (this code may or may not apply to your area). it will give you the required size of beams and joists based upon their spans, and how to build a code compliant deck.
Hope this helps ...
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 11-12-2012, 10:23 PM   #3
robertcdf's Avatar
No, you cannot use 6x6 for beams in most cases.
robertcdf is offline   Reply With Quote
Old 11-13-2012, 07:01 AM   #4
Framing Contractor
Hope this helps ...
He's saying that he wants to use 20' 6x6's 12' apart for girders perpendicular to 2x12's 16" centers.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-13-2012, 11:16 AM   #5
Rewards Points: 2,210
multiple (4) 2x6's or whatever actually make a stronger beam then a single 6x6.
Is headroom an issue?
Tell use the size of the area you want to build this deck. also the intended use.
If your going wall to wall ( or support) your going to need some large beams or engineered ones.
mae-ling is offline   Reply With Quote
Deck building around pool Ineedhelp2009 Building & Construction 9 03-30-2013 02:40 PM
Building a deck on a tar and gravel roof grmachine Building & Construction 2 05-30-2012 11:00 PM
Questions on building a deck off patio EClayton08 Building & Construction 12 05-28-2012 05:02 PM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 01:10 PM
building a screened in area on deck - deck heaves in winter burnt. Building & Construction 1 06-15-2009 11:35 AM
